5.3 heads for cammed 98 ls1
Old 03-02-2007, 07:53 PM
98SS1LWEE's Avatar
Default 5.3 heads for cammed 98 ls1
Okay, looking for some quick help. If got a set of 5.3 heads, any performance gains ove 806's? And if so, why? What's different? I know nothing of the 5.3 heads. Also, If good choice for cheap, then are they different sizes? Do i need new pushrods? Different anything else?
Old 03-02-2007, 08:12 PM
SSmoky01's Avatar
I would like to know as well. Anyone???
Old 03-03-2007, 07:01 AM
98SS1LWEE's Avatar
nobody can help us out?
Old 03-03-2007, 07:19 AM
S1LV3R's Avatar
I think the main thing is your gonna pick up compression over your existing heads. I don't know about your casting(806) but the 5.3 casting has the same runner as the 241's on the later camaros.
look here...https://ls1tech.com/forums/showpost....2&postcount=41
Old 03-03-2007, 07:50 AM
PREDATOR-Z's Avatar
The only way a 862 casting (4.8/5.3) will be beneficial is if it is fully ported with bigger valves.
otherwise it is the opposite, you'll loose power.
