The Official "Spun Bearing" Club
Old 03-03-2007, 12:22 AM
02TransAm/Batmobile's Avatar
Default The Official "Spun Bearing" Club
Hey guys: Engine Knock, Metal Shavings on Oil Plug, gonna take it to the dealer and hopefully will be covered by my warranty. Until then:
Join the Club. This is a support group for those who have lost their beloved LS1 due to Spun Bearings. Engine Knock? Metal Shavings? Bad Oil Pressure? WE understand. Talk with our many Counselors to help you through your hard times. We specialize in Post-Traumatic Stress Disorders relating to the first sight of metal shavings on your oil plug and help you "re-live" those experiences without anxiety. With repeated visits and bashing of a pinata in the shape of a LS1 Oil Pump, we have seen great success!
James - Founder and Tragic Owner
Old 03-03-2007, 12:24 AM
edwardswb's Avatar
sweet. We should have meetings!
Old 03-03-2007, 12:48 AM
nomorews6's Avatar
+1 on the meetings! I need some people to talk to!!
Old 03-03-2007, 12:58 AM
-=Modified=-'s Avatar
Hi my name is -=Modified=- and I have metal shavings and the worst knock ever after my MS4/PRC LS6 S1 install.
Can I cry on someones shoulder?
Old 03-03-2007, 01:01 AM
bayer-z28's Avatar
^ that's that damn valve tick... more like a knock now....
Small shavings... I'm wondering if it might be cam bearing related?? We lewb'd it, tho...
Old 03-03-2007, 06:16 AM
RGKSR's Avatar
Default Put me in the club!!
I just smiled and kept chanting "402, 402, 402........"
It will make you feel better.
Bob K.
Old 03-03-2007, 10:04 AM
VTC_WS6's Avatar
Yep i'm in the club, at least I think so heh. I had a nice knock going for a while which led me to installing a new motor, though I never did take the old one apart. I think at this point i'm too scared to find out it was something silly and I had my car down for over a year for nothing lol! Oh well, here's to new motors..
Old 03-03-2007, 11:02 AM
King James's Avatar
I didn't spin one bearing, I spun 4. I took some time away from the car, thought about selling it, but it looks like I'll be rebuilding it and beating on it again shortly.
Old 03-03-2007, 11:13 AM
slmdLS1's Avatar
There shall be more joy and happiness in my SS's future after #7(RIP) passed away. That joy and happiness is accompanied with cubic inches.
lots of them.
Old 03-03-2007, 03:08 PM
LS1MCSS's Avatar
This is one club I hope I never need/want to join. Wait, do past non-LS1 engines qualify? If so, I'm in there.
Old 03-03-2007, 03:55 PM
I actually plan on putting some useful information in this thread. Maybe it'll become a sticky?
Low Oil Pressure? Look into a new Oil Pump
You can bypass chaos caused by overspun bearings buy purchasing a heavy duty oil pump. Prices range from about 100-150 and to me, it's considered cheap insurance to keep your LS1 happy.
Texas-Speed.com: Ported and Shimmed LS6 Oil Pump - 139.99
Thunderracing.com: Ported and Shimmed LS6 Oil Pump - 149.99
SLP Heavy Duty Oil Pump: 185.99
Stock LS6 Oil Pump: 99.99
Melling HO Oil Pump: 139.99
Porting the Oil Pump on your own:
The path where oil pumps out from the oil pump is very disruptive and has many ridges. Take a grinder and port the hole. Like porting heads, grind out any surface irregularites to ensure a smooth oil flow. Next would be the installation of the spring. You could shim it yourself or purchase a shimmed spring which, in return, will have better pressure relief than the stock spring. Clean the pump housing and tighten the plug to 12 lbs. Be careful not to tighten it too much! When inserting the outer and inner gear, use a coat of grease for protection prior to startup. Place cover on and tighten to 12 lbs. again.
Stronger Bearings?
You could also purchase a set of stronger, heavy-duty bearings for a relatively cheap price too. They are priced at just under a 100 bucks. You could go with Federal Mogul or Clevite Bearings. Changing bearings? While you are in there, might as well go with stronger Connecting Rod Bolts from ARP.
So about 300 bucks, could save you from about 4 to 5 thousand or more dollars in a new assembled engine.
Tips: Check your oil religiously.
LS1's seem to suffer from oil starvation quite a bit. We all know to change your oil 3,000 miles and to regularly check oil levels. Be concerned also, when you have lower oil pressure. This could also be due to a different thickness levels in the vast array of oils out there. Thinner oil will read lower than thicker oil and hotter oil will read at a lower oil pressure than cold oil. Most of this is pretty much known information, but just in case you don't know, now you do.
James
Spun a bearing? Tell us your story, the cause and the outcome!
Old 03-03-2007, 04:14 PM
slmdLS1's Avatar
the pump that was in my LS1, was indeed a ported LS6 pump. just fyi.
Old 03-03-2007, 06:58 PM
1BAD02WS6's Avatar
i spun 7 bearings on a motor that lasted 600 miles
Old 03-03-2007, 09:02 PM
DuronClocker's Avatar
Slamming it into 2nd gear at the top of 3rd (105mph) slams valves into pistons, causing them to bend.
Bent valves make your car run very rough.
Continuing to drive it this way for a month and a half (and not nicely at that) eventually spins a main bearing, especially after racing a friend.
A spun main bearing drops your oil pressure guage needle to 10psi and you hear a faint--solid--knocking sound from the bottom end when leaning under the car.
Pulling this dead stock motor means you're going to spend a ton because you can't go through the hassle of swapping a new motor in without doing heads/cam/intake/pully/headers, etc. Also had new cam bearings and installed Clevite CH-series rod bearings with ARP bolts. It was a low-mileage stock bottom end.
I also spun 3 rod bearings in my old 305 third gen when the trans hesitated on a 6000rpm shift on stock bottom end ..........it then got a forged 355
Old 03-04-2007, 01:13 AM
tilly's Avatar
Hi my name is Tilly, and I am in the spun bearing club.
Bent a pushrod BALDLY changed them out, oil pump got sqUirely and I have a nice knock to the motor.
Old 03-04-2007, 05:08 PM
brad8266's Avatar
Threw a rod and it went bashed a hole in both the driver and pss side of the block.
oh well, I have a forged 347 with H/C/N20 now.
Old 03-04-2007, 05:30 PM
KillA98Z's Avatar
i bought my car with a spun bearing and a very loud rod knock.so loud it would drowned out the sound of the open borla.
Old 03-04-2007, 07:39 PM
Wow, I am learning alot! I remember during the summer, I went 1-2-3 back to 2. It wasn't a high rev, fast clutch action but I was afriad I might have bent a pushrod. It ran strong as a **** though afterwards. I wonder if that had anything to do with it.
Looks like a lot of folks with overspun bearings have great success stories, despite our services!
Old 03-04-2007, 11:48 PM
35th SS's Avatar
looks like Im in this club too.couple years ago on my m6 running on our local track.ran the bugga almost a quart1/2 low.spun the rod bearing.its fix ever since.lesson learned-always check your oil before racin.
Old 03-05-2007, 01:06 AM
BlackSVT03's Avatar
**** meetings... I need a ****** support group
Quick Reply: The Official "Spun Bearing" Club
