Oil pressue and spun bearing?
Old 03-03-2007, 04:37 AM
LS1 Hawkeye's Avatar
Default Oil pressue and spun bearing?
How big of an oil pressure loss would indicate a spun bearing? There was some metal on oil plug but nothing to worry about I didn't think. I noticed a loss of about 8-10 psi in oil pressure on the guage on the way home last night. Just trying to catch it before things really get bad. Thanks.
Old 03-03-2007, 06:48 AM
black01_WS6's Avatar
so what oil pressure are you seeing now. Usually when people have a spun bearing they see really low numbers for oil pressure. Mine will fluxuate 8-10 depending if im on throttle or not.
Old 03-03-2007, 10:05 AM
Tiger2o69's Avatar
When I had a spun main and a messed up cam bearing a I would see about 20 when cold and about 8 when hot..
Good luck.. You havent changed oils lately have you?
Old 03-03-2007, 10:59 AM
King James's Avatar
Mine never made an unusual sounds or anything, just a complete drop in oil pressure. That was the only sign other then a tremendous amount of metal in the oil.
Old 03-03-2007, 11:07 AM
slmdLS1's Avatar
mine dropped to 20psi and it took out a rod bearing.
Old 03-03-2007, 12:59 PM
SLO98Z's Avatar
Damn that looks disgusting. What kind of oil were you using? Quaker State? LOL
Old 03-03-2007, 01:05 PM
slmdLS1's Avatar
Mobil1 synthetic. you think yours is any cleaner after 80k miles? i dont.
Old 03-03-2007, 07:27 PM
SLO98Z's Avatar
Actually, I just pulled it at 78k miles and mine is a hell of a lot cleaner than that. I run Amsoil though.
Old 03-05-2007, 11:13 AM
It still has alot more pressure than 20 psi at idle and stuff, just haven't driven it for a while.
Old 03-05-2007, 11:24 AM
Thule's Avatar
my one spun out a bearing with fine oil pressure and enough oil?.. i dont understand it but the cars dont seems to bother
