longtube header install?
Old 03-06-2007, 10:16 PM
BlkT/A01's Avatar
Question longtube header install?
I got a quick ? to anyone that might know what is the average price from a shop to install longtubes and a Y??
Old 03-06-2007, 10:23 PM
tuffass's Avatar
to damn much! They'll want to pull the motor. I checked before I installed mine and heard a few in the 400-500 range so that was enough for me to free up a saturday to do it myself.
Old 03-06-2007, 10:27 PM
silverbandit0996's Avatar
but just do it yourself, its not that hard. plus it will instantly make you feel better about getting dirty on your day off when you start it up and think about all the money you saved.
Old 03-06-2007, 11:06 PM
00BlueTA's Avatar
It is not hard, just take your time and make sure you plug everything back in when your done.
Old 03-07-2007, 12:05 AM
yea be sure not to forget the coolant temp sensor. cause i did.
Old 03-07-2007, 12:10 AM
chewy99ws6's Avatar
yea save your money and do it yourself, easy as hell
Old 03-08-2007, 07:35 PM
BlkT/A01's Avatar
Don't i have to pull the engine? And i don't have an engine lift.
Old 03-08-2007, 08:18 PM
chewy99ws6's Avatar
no, just get the car up high enough and slide them in from underneath, to make it little easier pull off your coil packs, 5 10mm bolts, gives you more room.
Old 03-08-2007, 08:21 PM
00slowredz's Avatar
get someone to help you, its a lot easier if someone starts the bolts up top while you hold them in place
Old 03-08-2007, 08:46 PM
BlkT/A01's Avatar
OOO man im going to screw something up. I just know it.
Old 03-08-2007, 08:52 PM
chewy99ws6's Avatar
you want mess anything up, they are so easy to install.
Old 03-08-2007, 09:15 PM
BlkT/A01's Avatar
Ok i looked at it and it just seems that i have to pull the spark plugs, the power steering computer, the coil that it connected to the heads, and maybe the alternator. I however don't know what i have to pull off under the car because i didn't get a good look...... Does that sound right?
Old 03-08-2007, 09:27 PM
ArrestMeRed99Z28's Avatar
No, I had to remove: dipstick tube ( ), spark plugs, pass side coil packs (as an assembly), and the starter.
Feel free to PM me if you have any questions.
AJ
Old 03-08-2007, 09:38 PM
97stroker's Avatar
Yeah you should have few problems with the install, especially since you aren't installing them in an LT-1 era car. Now thats a pain in the a**!!
gyrene2003's Avatar
listen man, when i did mine i made a thread in my reginal section and asked some guys i knew for some help on the weekend. I was in your same boat 2 weeks ago. I knew i could do it myself but i wanted the watchful eyes and steady hands of experience with me. Just look up some f-bod friends or try and make some and find a lift or some good jack-stands and ull be alright. Also, i removed the dipstick and coilpacks but not the alternator.
Old 03-08-2007, 10:50 PM
chewy99ws6's Avatar
remove the dipstick and pass. side coil pack as a whole and get the car high enough and they will lide right in, that is all I did.
Old 03-10-2007, 10:26 PM
Mike @ New Era's Avatar
We charge $250 on an LS1 f-body, you don't have to pull the engine.
Old 03-11-2007, 01:39 PM
magius231's Avatar
I did my own, but if I had to do it again, I would seriously consider $250 to have someone else do it
