What Head Studs For Lme 408 Iron Blck ?
Old 03-07-2007, 12:24 PM
wicked z28's Avatar
Default What Head Studs For Lme 408 Iron BlOck ?
What Arp Head Studs Are You Guys Useing On Your Lme 408 Iron Block My Heads Are Ls6 Milled 55 Thous. Cnc Gm Performance Parts. I Bought The Short Block A Little Over A Year Ago.what Part Numbers And How Much And Were.
Old 03-07-2007, 12:26 PM
brad8266's Avatar
ARP Studs FTW!!!
Old 03-07-2007, 12:56 PM
wicked z28's Avatar
What Do You Mean Ftw
Old 03-07-2007, 01:09 PM
brad8266's Avatar
for the win, lol. Just get the arp studs, they are the best out there.
Old 03-07-2007, 01:26 PM
wicked z28's Avatar
Ok,but Were Did You Buy Yours And How Much,who Has The Best Deals.the Ones I Need Are The 04 And Up Right.
Old 03-07-2007, 01:28 PM
brad8266's Avatar
If the block is a new one yes you will need the 04 and up studs, they are shorter I believe. I would check on a few of the sponsors websites to see who has the best prices. The are in the $250 range. They are well worth it too. Check TSP and Thunder.
Old 03-07-2007, 03:04 PM
wicked z28's Avatar
Thanks I Apreciate The Info Will Do
Old 03-07-2007, 05:12 PM
DONAIMIAN's Avatar
Any reason for using the studs instead of the stock bolts?
Old 03-07-2007, 05:54 PM
brad8266's Avatar
They last forever, only have to clean the bolt holes one time which reduces the chances of damaging the block threads or cracking the block. Reusable.
Old 03-07-2007, 06:12 PM
wicked z28's Avatar
How Do You Clean Them,with A Pressure Hose.THE 408 GOING BE SPRAYED ALSO.
Old 03-07-2007, 06:16 PM
brad8266's Avatar
Clen the bolt holes out with air. They must be completely clean and dry when you install the studs.
Old 03-07-2007, 06:22 PM
tomulrich's Avatar
Actually A1 Technology makes the strongest studs. Made from MP-35 alloy. 290psi tensile strength...also set you back 1000.00 dollars.....
Tom
Old 03-07-2007, 06:38 PM
wicked z28's Avatar
Wow Thats Steep
Old 03-07-2007, 06:42 PM
brad8266's Avatar
Tom
Hmm 750 more dollars for an extra 90 PSi tensile strength. Ill stick with the cheaper ARP's unless I am pushing over 40 PSI or over a 550 shot of juice.
290 is a very stong piece.
Old 03-07-2007, 11:21 PM
DONAIMIAN's Avatar
I know that, im just saying that most people that ive seen go the stud route never really justify their purchase. The stockers have seen a lot of juice in testing, I honestly wouldnt have a problem using them in a big CI/juiced set up.
Old 03-08-2007, 07:03 AM
brad8266's Avatar
Studs make it much easier to place the head and gasket on and get a perfect alignment too. Plus not having to clean the bolt holes everytime you pull the heads is enough justification for studs. Cleaning bolt holes is PITA.
