1 or 2 bolts on pick up tube?
Old 03-10-2007, 08:57 AM
finallygot1's Avatar
Default 1 or 2 bolts on pick up tube?
Are there one or two bolts on the oil pick up tube? Haven't got that far yet, just planning.........
Thanks,
Old 03-10-2007, 09:02 AM
JPH
JPH's Avatar
Thanks,
1 BOLT.
Old 03-10-2007, 09:09 AM
My new pump has 2 sets of threads, part # 12586665
Old 03-10-2007, 10:06 AM
mr2guru's Avatar
For different pickup apps probably. You only use one.
Old 03-10-2007, 10:31 AM
Thimble's Avatar
The F body pickup tube uses the inside bolt hole.
C5's use the outside bolt hole.
Not sure about other cars...but yes,the tube flange only has one hole in it.
It will make sense when you see it.
Old 03-10-2007, 10:36 AM
Phantompooper's Avatar
Don't lose that O-ring either, my cam swap took another day because my father-in-law and I had to take the front end apart cause I wasn't getting any oil pressure.
Old 03-10-2007, 10:48 AM
Ferocity02's Avatar
Yes, 1 bolt, but it's a worst mother ******* bolt on the entire car. Have fun
Old 03-10-2007, 11:09 AM
I've never cussed so much in my life as I did at that #@%$&ing bolt.
Old 03-12-2007, 04:04 PM
Bill Bowling's Avatar
I guess I lucked out, mine was easy to get in.
Bill
Quick Reply: 1 or 2 bolts on pick up tube?
