thread locker?
Old 03-10-2007, 10:08 AM
Timonator's Avatar
Default thread locker?
What bolts should I use thread lock on?Rockers?,Front cover?oil pan?oil pump?pickup tube?cam retainers?
Old 03-10-2007, 11:33 AM
Fratsit's Avatar
I used it on the cam retainer, oil pump, oil pump P/U, crank bolt, front cover, and upper timing sprocket. I did not use it on the pan.
R/
Frat
Old 03-10-2007, 11:43 AM
shouldaboughttheZ's Avatar
I used it on rockers, cam retainer, crank bolt, upper timing sprocket.
I didn't touch the oil pump.
Old 03-10-2007, 04:04 PM
brad8266's Avatar
I used red locker an just about every bolt on the engine.
Old 03-10-2007, 05:21 PM
JPH
JPH's Avatar
cam retainer/gear bolts, oil pump, pick up tube bolt. sealent on intake rocker bolts, oil on everything else and trq. to spec.
Blk97WS6's Avatar
I used it on everything as well, except for the oil pan.
Old 03-10-2007, 07:18 PM
1BADAIR's Avatar
I wouldn't use red on the rockers. I would use blue/thread sealer on those
Quick Reply: thread locker?
