Pushrod size
Old 03-13-2007, 12:34 PM
Jrp1978's Avatar
Default Pushrod size
What size pushrod should i use on a stock 2002 camaro with a tr 224 cam . I was thinking maybe like a 7420 to maybe quite down valve train . Would that work or am i off base here?
Old 03-13-2007, 12:35 PM
brad8266's Avatar
that should work ok,what is the base circle of the new cam?
Old 03-13-2007, 02:27 PM
Jrp1978's Avatar
Default ok
Tell me how to measure it and I will let you know!
Old 03-13-2007, 02:45 PM
SSpdDmon's Avatar
Is there an easy way to determine the base circle? I have an idea of what cam I'm running. But, the car came this way. So, I don't have the actual cam card. I only know it's a CompCams 232/238 .595/.605 XE-R 112LSA cam. I too would like to know appropriate PR size if there's an easy way to compute...
Old 03-13-2007, 07:00 PM
JPH
JPH's Avatar
7.400-7.425
Old 03-13-2007, 07:23 PM
Arcolog2's Avatar
Get a pushrod length checker.
Old 03-13-2007, 07:29 PM
brad8266's Avatar
new pushrod length = ((stock cam base circle-new cam base circle)/2) + stock pushrod length - amount heads are milled - difference between new head gasket and old head gasket.
Stock base is 1.553, stock pushrods are about 7.39, stock head gasket is about .052
To measure base circle get a dial caliper and put it on the cam lobe and turn the lobe until the dial reads its lowest point, that low point is your base.
Old 03-13-2007, 10:51 PM
Arcolog2's Avatar
Brad's the man, can't wait to see your car running again THursday night bubba!
I'm PRAYING my headers come back from Kooks soon....
Old 03-13-2007, 11:16 PM
mvvette97's Avatar
Just wondering, are you supposed to measure the base circle radius or the diamater? On my stock cam it was .775 on the radius and my comp cam is a .732 so that means my Comp is .043 smaller. I added that to the length of my stock pushrods so 7.396 + .043 =7.439. I went with 7.425 because the next size up was 7.450 and didn't know if it would hurt to go over the factory preload. So anyway is this how you figure it?
Old 03-14-2007, 09:14 PM
NoMoreFWD's Avatar
Yes. You have done well.
Old 03-14-2007, 09:22 PM
brad8266's Avatar
Ill be there. Yeah it is nice to have the car back again. So you sent the header with the hole back to Kooks for repair huh? Did they cover it?
Old 03-18-2007, 04:47 PM
Arcolog2's Avatar
Yes they did, they paid for shipping to them and back as well as turning them into race style headers and getting rid of the AIR all together.
Then they gave me a deal on Jet Hot too.
Old 03-18-2007, 05:18 PM
brad8266's Avatar
good deal man
Old 03-19-2007, 01:07 PM
Jrp1978's Avatar
Default Hmmmmmmmm
All i want is will 7.425 work better than 7.400
Old 03-19-2007, 01:17 PM
mvvette97's Avatar
Yes, it will give you more preload and quiet it down some
