Can you identify a LS6 camshaft.
Old 03-13-2007, 10:35 PM
01WS6/tamu's Avatar
Default Can you identify a LS6 camshaft.
I bought an 02 ls6 cam from a member here and when held side by side to my 5.3 cam they look identical. Is there any way to positively identify what it is, and if it is an ls6 cam. On the back end of the cam there is a 4 sequence number on the top two digits under it and then another four digit number under that. Is that bits and pieces of a part number. Thanks.
Old 03-13-2007, 10:37 PM
NviouSS's Avatar
pn for an 02 ls6 cam is 12565308.
Old 03-13-2007, 10:45 PM
SilverSS's Avatar
Maybe try measuring the base circle with a caliper. 02+ ls6 = 19mm from center or 38mm across. .7480" from center or 1.496" across.
Old 03-13-2007, 10:57 PM
01WS6/tamu's Avatar
So is the number that is on the end is a gm part number then.The number of the back of the cam is 5306 s06 2166. Anyone know what it is?
Old 03-13-2007, 11:28 PM
2xLS1's Avatar
Are you sure it's not 5308 as in 12565308?
Old 03-13-2007, 11:40 PM
01WS6/tamu's Avatar
Went back out and double checked it is 5308. Is there a snowballs chance in hell of it being a 02 ls6 cam considering those are the only four numbers that match.
Old 03-14-2007, 08:22 AM
2000TransAmWS6's Avatar
yep, thats what it is... a 02+ LS6 cam.
i don't know why, but they only match those last 4 numbers
Old 03-14-2007, 08:26 AM
01WS6/tamu's Avatar
Thanks a bunch appreciate it.
