Valve spring? *pics*
Old 03-13-2007, 11:04 PM
DocEwww's Avatar
Default Valve spring? *pics*
Car was acting strange today while running my buddy's stang, changed the oil tonight and found this on my drain plug. Had class early, was too lazy/tired to pull the vavle covers afterwards.
Old 03-13-2007, 11:06 PM
dub.ya.es.SICK's Avatar
time to upgrade and cam it bummer man
Old 03-13-2007, 11:09 PM
DocEwww's Avatar
They're PRC dual springs
Old 03-13-2007, 11:19 PM
mvvette97's Avatar
your lucky they are duals. I had some 918 singles break and that was scary
Old 03-13-2007, 11:35 PM
DocEwww's Avatar
I would have just drove the car off a cliff if I had dropped a vavle, its a brand new engine.
Old 03-13-2007, 11:45 PM
mvvette97's Avatar
I know, I was about to have mine crushed. Bought the car all stock. Ran nice but had to mess with it. i done a cam swap and the hell began. After a couple 100 miles it developed at bad tick, tried every differant length pushrod made, nothing helped. Then broke 8 of the comp 918 springs so then I switched to duals. ran good for just a bit and started ticking again. So I pulled the heads and put new lifters in AND a new cam again. Going back togethor I moved the ac condensor too much and broke the ac line. So now my air doesn't work. Anyway after all the **** it still ticks Not bad but I can hear it. It was quiet before I messed with it. I even have the correct length pushrods so maybe the ticking is normal with a cam, hell if I know. But I was very lucky when my single springs broke. It could of been bad.
Old 03-14-2007, 12:01 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Better hope that you don't have some spring metal bouncing around in your bottom end. That made it all the way to the plug? YIKES!
Old 03-14-2007, 12:23 AM
01ls1lover's Avatar
Ahhh! Stop the storys! Im installing my cam and 918's soon...
Old 03-14-2007, 12:28 AM
sidewayz28's Avatar
^DONT DO IT MAN!!! youll regret it.
Old 03-14-2007, 03:45 AM
Krab's Avatar
Looks like the upper pieces of the outer valvespring to me. I wouldn't drive it around anymore until I fixed that. How many miles on the springs?
01ls1lover: Not everyone has bad luck with a cam swap. Mine's going strong with almost 30k miles on it.
Old 03-14-2007, 05:55 AM
99blancoSS's Avatar
How many miles on those springs? What cam are you running? Important info here, lot of people with PRC springs...like me
Old 03-14-2007, 07:59 AM
SScott236's Avatar
Maybe a spark plug is loose.
Old 03-14-2007, 09:29 AM
Hell'sChariot's Avatar
Me too!!
Old 03-14-2007, 10:40 AM
Xtnct00WS6's Avatar
What caused this?! How many other failures have there been?
I'm going to be installing Patriots Gold Extreme springs and I'm pretty sure they come from the same factory.
Old 03-14-2007, 10:42 AM
mvvette97's Avatar
what's a matter? I'm not scaring you guys am I? I just had some bad luck for a while.
Old 03-14-2007, 11:30 AM
DocEwww's Avatar
About 7K on the springs. Running the TTP V4 Punisher cam which is a large comp cam, especially in the lift.
Old 03-14-2007, 11:36 AM
Xtnct00WS6's Avatar
What are the specs? Or at least approx. specs?
Old 03-14-2007, 04:39 PM
GuitsBoy's Avatar
HUUUWWWHHHHAAAATTTTT??????
Old 03-14-2007, 08:01 PM
trans2000am's Avatar
did you run the car hard as soon as you started it? surpose to let them heat up before you go WOT
Old 03-14-2007, 08:19 PM
Boodyrider's Avatar
Well, no...
Correction "They WERE PRC dual springs"
My question is what was installed height and clear at max lift?
