is this piston ok? (pic inside)
Old 03-14-2007, 11:15 AM
nomorews6's Avatar
Default Dreaded Piston Scratches! *PIC*
I am looking on buying a used motor and was told it is possible a valve broke loose and danced on the piston a bit perhaps.
http://www.tannercreative.com/piston.jpg is the file - i'd put the image here but it is too big. It is a -11cc lunati piston.
Old 03-14-2007, 11:38 AM
ibanez7's Avatar
i would polish that out and make it smooth, it should be fine... I would worry more about your cylinder sleave...
how deep are the scratches?
Old 03-14-2007, 01:44 PM
PREDATOR-Z's Avatar
It is a bit of a risk, because you cannot see if there is any damage below the line. IMO look somewhere else.
Old 03-14-2007, 04:34 PM
GuitsBoy's Avatar
First off, predator makes a good point. Second, ibanez7 suggests sanding and polishing out the scratches, but that potentially lower compression on only one cylinder. Third, theres a good chance the cylinder wall is scratched up too.
