can i use stock pistons with 59cc heads?
i was reading some thread here on the forum, and someone was saying that with 59cc heads you can not use stock pistons,
is that rigth?
is that rigth?
Well it is a double edge question "You can use stock pistons But"
1- if 59cc was achieved by milling a head your choice of cam is limited (if head is GM casting)
2- The GM casting that offers the most clearance at 59cc is a 6.0L casting with welded chamber (Like Patriot LS6 "style")
3- There are aftermarket castings like ETP and AFR that offer enough clearance for some BIIIG cams.
