Valve Springs: Single or Dual?
Old 03-16-2007, 12:57 AM
Lonewolf37's Avatar
Default Valve Springs: Single or Dual?
I am changing cams in my 2001 z28. I plan to use a GM Hotcam. I am considering which valve springs to use. Do dual valve springs offer advantages?
I am especially concerned with the knock sensors.
Old 03-16-2007, 02:46 AM
SDMForever's Avatar
I would still go with singles you really only nead dauls when you have a very large cam like lift over.600
Old 03-16-2007, 05:06 AM
vettenuts's Avatar
I personally like the beehive spring design as it is light and the retainers are light. They also have less intense harmonics, but in reality you can go either way.
Old 03-16-2007, 08:21 AM
marv's Avatar
Should be able to run singles with that cam just fine...
Old 03-16-2007, 09:02 AM
TRANSAM_2000's Avatar
I would like to know the same thing i have a patriot 226 226 585lift cam should i use the patriot dual springs with that cam if not what should i get.
Old 03-16-2007, 09:08 AM
2000TransAmWS6's Avatar
^bud, CompCams 918 springs would probably be a good idea for you.
with the hotcam just use LS6 springs (blue or yellow), thats what i used when i ran the hotcam
Old 03-16-2007, 09:10 AM
marv's Avatar
Typically from what I've seen, dual springs are not needed until you get right at .600 lift. However, I'm sure there are exceptions to the rules.
I would say singles would be fine (Comp 918s maybe), however it wouldn't hurt to check with one of the sponsors on the right to make sure.
Better safe than sorry.
Good luck.
