Do I need a special thread chaser for the lq9..
Old 03-16-2007, 02:48 AM
bcs
bcs's Avatar
Default Do I need a special thread chaser for the lq9..
I need to clean out the head bolt holes.I know with ls1 you use the ARP thread chaser 11mmx2.00
Old 03-16-2007, 10:26 AM
12secSS's Avatar
It is the same thing. Although depending on the year of the Gen3, it could have different lengths head bolts or all the same size.
Old 03-16-2007, 04:06 PM
Beast96Z's Avatar
The bolt holes are the same diameter/pitch. Just make sure it is the ARP tool you are using because a standard cutter will take the "roll" off the threads and weaken them.
Old 03-16-2007, 08:43 PM
bcs
bcs's Avatar
Thanks guys..This is my first so wanted to make sure.
I was told for the lq9 that I have to use the shorter ls2 bolts.
Quick Reply: Do I need a special thread chaser for the lq9..
