PRC Stage 2.5 heads good match for TR224?
Old 03-18-2007, 01:30 AM
MannyZ28's Avatar
Default PRC Stage 2.5 heads good match for TR224?
I am looking into buying some heads for my car. Current stats on the car:
98 Z28 M6 with stock gears
Stainless Works Headers with 2.5" Y pipe
TR224 112 LSA cam
LS6 intake
Ported Throttlebody
Coolant Bypass
918 springs
TR hardenend pushrods
Taylor 10.4 mm wires
ASP pulley
B&B Triflo exhaust
QTP cutout
NGK TR55IX plugs
LS6 ported oil pump
Katech timing chain
BMR LCA's
SLP SFC's
UMI double adjustable dual rod ended PHB
Spohn adjustable body mounted torque arm with longer bolts
uh....and yeah....Direct flow lid
currently the car only makes 375 rwhp and 367 rwtq after a dyno tune. I am trying to break 400...425 would be nice. Will the PRC 5.3L 220cc Stage 2.5 heads work well with my TR224 and the rest of my setup?
Any input welcome!
Thanks!
Manny
Old 03-18-2007, 03:07 AM
PREDATOR-Z's Avatar
Yes, put that on with a set of Cometic .040 (for added compression, DCR and quench) and you have a good killer street setup.
Old 03-18-2007, 08:32 AM
john563's Avatar
IF your talking about the TSP stage 2.5 5.3l heads,Well i got those heads and that cam in an A4(auto) and put down 417rwhp and 407ft,but i also have aported fast.Dont know what you will get in a six speed,but i hope this helps
Old 03-18-2007, 01:02 PM
MannyZ28's Avatar
Did you ever dyno with just the cam?
Old 03-18-2007, 02:06 PM
Krab's Avatar
I wouldn't doubt you hitting your goal of 425rwhp with your setup. We have similar set-ups and with some untouched 243 heads, I hit 411rwhp. Cam only I put down 376rwhp.
Old 03-18-2007, 07:45 PM
john563's Avatar
yes it did 350rwhp
Old 03-18-2007, 09:36 PM
MannyZ28's Avatar
yes it did 350rwhp
Damn...was that with the ported FAST?
Old 03-18-2007, 09:52 PM
oange ss's Avatar
TR 224/.563 114 LSA cam + bolt ons
+ PRC Stg 2.5 heads (conservative N2O tune)
Old 03-18-2007, 09:57 PM
MannyZ28's Avatar
Wow...your dyno sheet looks a lot like mine with current mods...
That sure gives me hope for the numbers I want!
Old 03-19-2007, 01:35 PM
john563's Avatar
no that was with an ls6.When i added the heads i upgraded to the fast
Old 03-19-2007, 01:37 PM
'Trust''s Avatar
MannyZ28, you need to adjust the smoothing on that graph, it may read a tiny bit lower, but it will be more accurate. As far as the PRC's, I've heard nothing but great things about them, however you will have to flycut, but thats not really a big deal. I say you'll be around 420ish with em'.
Old 03-19-2007, 02:06 PM
oange ss's Avatar
get the smaller valve version...
Old 03-19-2007, 03:48 PM
LS1Formulation's Avatar
I've called about the Stage 2 5.3's before and they said i wouldn't have to flycut even with a 220/224 LSK lobed cam.
Old 03-19-2007, 04:07 PM
apexman's Avatar
Should be a great setup. I have a TSP 225/589/112 +2 with LS1 MTI stage 2e's and did 427hp and 392 Tq in my vette before a tune. Peak #'s didn't go up with the tune but gained 10 to 15 in tq under the curve. Oh, this is with an LS6 intake and non ported TB and Jet Hot headers. Budget mobile.
Also, heads were unmilled with stock gaskets.
Old 03-19-2007, 04:08 PM
Flipn's Avatar
thats good to hear.. I hope that I dont have to flycut with my combo.. TR224/224 with PRC LS6 milled to 59cc..
Old 03-19-2007, 04:21 PM
Ryan02SS's Avatar
I have very early 2003 Patriot 5.3's and make numbers in sig. Combo has a great powerband and makes 352rwtq @ 3000rpms! Cam only TR224 made 389rwhp @ 37? rwtq. You should not have to flycut for that combo. I had around .250" PTV clearance when checking mine.
Old 03-19-2007, 08:54 PM
99blancoSS's Avatar
You dont need to flycut with prc 5.3's and a tr224. Its a great combo!! You wont regret it manny
Old 03-19-2007, 09:20 PM
MannyZ28's Avatar
Thanks for all the great input guys! Yeah, my car is not exactly a dyno queen as can be seen by my low numbers, then again, the 98's had the worst flowing heads, so I'll blame that and the horrendous heat during the time this dyno was done
