Should I be worried??
Old 03-19-2007, 06:54 PM
blkbird's Avatar
Default Should I be worried??
I started noticing that my oil pressure is going down little by little. At first I thought it was the OPSU, so I replaced it with an new AC delco. It was working good at first but now it has me wondering. OK, here is how it happens. When I start it up the o/p is about 42psi on a cold start and once warmed up is about 38-40psi. I drive it without getting on it and at about 40psi in 6th doing about 70mph. Now after i come to a stop it drops down to about 28-30psi at idle. Sometimes it show that and sometimes it show 38-40psi at idle (both reading while the car is fully warmed up). When I did my cam swap a year ago, i put in a brand new LS6 oil pump and my pressure was good (42psi idle and 45psi driving). When I turn on my A/C it drops to about 25psi at idle. Should I worry about this?? The motor isnt making any noises and the pressure does go up when I step on the gas. Any thoughts??
Old 03-19-2007, 07:04 PM
67Firebird455's Avatar
That's strange. Try a manual pressure gauge and see what kind of reading you get. I wouldn't worry too awful much just yet, that is quite a variation though, considering they're both tested warm, not sure...
Old 03-19-2007, 09:01 PM
blkbird's Avatar
I know, it baffles me also.....
Old 03-20-2007, 03:04 PM
3.4camaro's Avatar
that's plenty of oil pressure. My 3.4L had 5-10psi a idle. You should not be worried.
Old 03-20-2007, 03:08 PM
Asmodeus's Avatar
I don't think it's the pressure itself that's causing him to worry. I think it's the change in pressure over time he's been noticing that has him thinking.
Old 03-20-2007, 03:30 PM
blkbird's Avatar
Yes, it has slowly been decreasing over a period of time.
