Car Idling High
Old 03-19-2007, 09:55 PM
RoastEmSS's Avatar
Default Car Idling High
finally got the car back together after taking the heads off, everything is running fine except it is idling at around 2100 rpms and I'm throwing 2 maf codes.. even tho I've been running SD since last June and never had any thrown codes until now. Also when I give it any gas it's almost like the throttles sticking.. maybe it had gone back to maf tune due to the battery being unhooked causeing it to idle high? or a vacuum leak maybe? help is greatly appreciated
Old 03-19-2007, 10:16 PM
ArcticZ28's Avatar
Vacuum leak is my bet. You don't lose a tune by disconnecting the battery.
Old 03-19-2007, 10:22 PM
DONAIMIAN's Avatar
Yeah, I want to say vac leak also. Either that or you have a bad TPS (happened to me).
