g5x3 dynoed tuned
Old 03-20-2007, 03:33 PM
CASHss99's Avatar
Default g5x3 dynoed tuned
with my current mods i got
Old 03-20-2007, 06:51 PM
CASHss99's Avatar
any thoughts
Old 03-20-2007, 06:53 PM
stevewix's Avatar
any timing numbers for me?
Old 03-20-2007, 07:58 PM
noxiouSS's Avatar
seems a little low??
Old 03-20-2007, 09:02 PM
crazylane's Avatar
Thats really low from all the other people that I have seen with G5X3's. Thats the cam I am going with, so hopefully I will have better luck. Hope you figure it out man.
Lane
Old 03-20-2007, 09:29 PM
SPRAYED 01's Avatar
That can not be right. I have a very similar cam and did 430hp on a 4000 stall auto with a 9inch and steel driveshaft on a Mustang dyno. You should get that back on and do some more tuning. Also, what are you supporting mods besides the cam?
Old 03-20-2007, 09:31 PM
SPRAYED 01's Avatar
Never mind just read your sig. Should be abot 400 with the converter locked which is probably not how they dyno.
Old 03-20-2007, 09:35 PM
crazylane's Avatar
Originally Posted by SPRAYED 01
Never mind just read your sig. Should be abot 400 even with the converter unlocked which is probably how they dyno.
You have the same exact cam I ordered, do you happen to have a sound clip of it.
Old 03-20-2007, 10:16 PM
SPRAYED 01's Avatar
http://video.google.com/videoplay?do...92109621033441
This is cutout open untill the very end and i close it. Did you think of this custom grind or did someone recomend it to you?
Old 03-20-2007, 10:26 PM
Cop Car's Avatar
if mine dynos that id cry... hard.. for a very long time
Old 03-21-2007, 04:29 PM
CASHss99's Avatar
i dunno guys, he said theres no way i can get 400 with just a cam
Old 03-21-2007, 04:30 PM
CASHss99's Avatar
i only heard teh car go 3 times on the dyno then a quick around teh block.. i think he just half assed it.. it hits real hard on a launch tho but when i was waiting the car sat on the dyno for quite a bit
Old 03-21-2007, 04:38 PM
King James's Avatar
Realize you have a 99 with a loose stall and 3.73 gears before you go dyno racing. Those number may be a bit low, but honestly they really aren't that bad. With some more fine tuning you might see 380. I don't see a pulley on your list of mods, that should help get you whatever magical number your after.
Get it on the track and see what it runs before you really start getting depressed. And remember, every car is different. Just because Joe Blow dyno'd XXXhp doesn't mean your car will do the exact same.
Old 03-21-2007, 05:07 PM
CASHss99's Avatar
ooops your right i have asp underdrive pully
Old 03-21-2007, 05:10 PM
CASHss99's Avatar
thats true but out of 6 hours ive seen teh guy in my car about maybe 2 of them did 3 pulls... i asked him bout the numbers he said that really shouldnt matter my car should easily with a tire do 11.80s
Old 03-21-2007, 05:25 PM
Nasty99SS's Avatar
hmm im swapping my cam out for the g5x3 i seen some people dyno pretty high with it
Old 03-21-2007, 05:39 PM
CASHss99's Avatar
yea i dunno man ive seen a majority with alot higher numbers
Old 03-21-2007, 05:45 PM
DONAIMIAN's Avatar
That car should deff make 400rwhp and should go decently into the 11's with a drag radial. Time to find a new tuner.
Old 03-21-2007, 05:46 PM
00 Freak's Avatar
I have a buddy that has the g5x2 which is a lil smaller and he dynoed 399.xx with stock heads besides the required valvetrain, no pulley, auto, 373s headers, and slp LM. Like said before take to the track and you'll find if it's true about your ##. If he knew how to tune LS1 cars he would've known better the capabilities of these car. There's many many many guys that make over 400 rwhp with cam only.
Old 03-21-2007, 06:04 PM
01LS6SS's Avatar
Ive seen stock 02 Z06's hit that #. Sounds low.
Quick Reply: g5x3 dynoed tuned
