head bolts and summitracing
Old 03-20-2007, 09:32 PM
onecamaro1's Avatar
Default head bolts and summitracing
I just made the head gasket post but i have another issue. I have no head bolts so i called summit to see if they were reusable arp's. They said yes, but no more that 3 times, which is $155. the GM torque to yield ones are $38, which x3 = $114. I am only running the Z06 package, nothing fierce. What should i do? DD car.
Old 03-20-2007, 09:35 PM
cowboysfan's Avatar
ARP's are reusable and yes, max 3x's gm's stretched to yield one time use.
fuerzaws6
Old 03-20-2007, 09:38 PM
marv's Avatar
Considered using studs (ARP)? That's what I went with and they worked great.
Seemed easier to do than using bolts as well.
Plus you don't have to clean bolt holes each time...which is always good.
Old 03-20-2007, 09:39 PM
finallygot1's Avatar
My 2 cents, I don't think ARP head bolts are worth the $$$$$. All LS1/LS6 motors are built with GM head bolts, when did they fail? I think ARP bolts are worth the money in certain applications, but not here, again just my 2 cents.......
Old 03-20-2007, 09:41 PM
onecamaro1's Avatar
question about the studs, it looks as if you can't put the head on while in the car on the passenger side.
Old 03-20-2007, 09:43 PM
marv's Avatar
You can...I've done my last two sets with them. It does appear that it'll be close, but they will go on.
Just be careful to not scratch/damage the heads on one of the studs when you do it.
Old 03-20-2007, 09:48 PM
onecamaro1's Avatar
are the studs 3x use also?
Old 03-21-2007, 07:34 AM
marv's Avatar
I'm not sure...but that's a great question. If so, I need to know...haha.
May have to call ARP today and find out. I wouldn't think they were...
Old 03-21-2007, 04:32 PM
Gunnar@Patriot's Avatar
We can sell you a set of OEM head bolts for $20.00. Just give us a call and we will get you fixed up.
