Oil pressure on high mileage car
Old 03-21-2007, 06:19 PM
Rob98LS1's Avatar
Default Oil pressure on high mileage car
My car has about 170000 miles on it and as far as I know its the factory drivetrain. When it gets up to temp, it will idle around 30psi, sometimes a little higher but its pretty consistant. Its not burning much oil but I'm wondering if this is typical of a car with this many miles on it? I drive it pretty dosile but I have taken it to the track once before when it had less miles. Just wondering other people's opinion on this, since it seems to be a bit lower than what most other member's car are running at.
thanks for your input,
Rob
Old 03-21-2007, 06:42 PM
brad8266's Avatar
Thats a little bit lower than most cars at idle. The oil pump may slowly be going bad.
Old 03-21-2007, 06:48 PM
Rob98LS1's Avatar
thank you for your input! I was also considering my oil pump.
Old 03-22-2007, 08:22 AM
marv's Avatar
I agree with Brad...a bit low...
Mine has 116k on it and usually holds 40 psi at idle...
Old 03-22-2007, 08:42 AM
SERIALPIMP's Avatar
That is typical of a car with that kind of mileage,
I would not worry about it,
Teh rings don't seal as well and everything does not seal as well with that kind of mileage,
You wouldn't expect it to act like a brand new car,
As long as its fairly consistent and not dropping down in into the teens,
I would not sweat it,
Old 03-22-2007, 09:19 AM
ProStreetBiker's Avatar
Although ring wear goes along with increased mileage, I would say that bearing wear would be the reason his oil pressure had dropped. Also, the pump's bypass spring is probably getting weak and the factory gauge isnt that accurate anyway.
Old 03-22-2007, 09:46 AM
01Z28M6's Avatar
Before you go about the significant effort of replacing your oil pump you might think about verifying the accuracy of your sender and gauge. I replaced the sender on my LT1 engine and gained nearly 15 lbs of pressure at idle. I thought the engine was on its last leg until then.
BTW, it is usually the cam bearings that lower oil pressure. If main or rod bearings are worn enough to drop pressure then the engine is making ominous noise or will be shortly. Fuel injected engines will not wear cylinder walls or rings for a great length of time due to the proper air / fuel mix that keeps from washing the cylinder walls of lubrication. Most modern engines can easily go 200k and show little wear.
Old 03-22-2007, 09:47 AM
bczee's Avatar
I would said that is typical of a high mileage car in that range, Rings would not have too much to do with the low pressure. But bearing and the Pump spring are most likely showing there age.
What is the pressure at higher RPM's ? General rule of thumb is 10psi for every 1K of RPM.
Old 03-22-2007, 10:52 AM
bjamick's Avatar
Well i just put a high flow melling on my 160k mile LT1 and it just bout pegs the Guage at 80psi when i give it some gas . LT1's are a PITA to change the oil pump in, not for sure bout the LS1 but i know LT1's sukkkkkkk
Old 03-22-2007, 12:29 PM
lt1formula2000's Avatar
seems like ok pressure just watch for any sudden changes in the pressure, such as 30psi this week 20 next week then 10 etc.. and yes bjamick it sucks on the lt1 I had to drop the pan to reattched the pickup tube on my lt1 car it sucked. Ls1 pumps on on the crank behind the timing cover.
Old 04-23-2007, 05:44 PM
Rob98LS1's Avatar
damnit i'm sorry forgot i posted this thread cuz I wasn't getting any info before it slid off the first page. Anyways, The car doesn't have any knocking going on so that's good. The pressure has always been consistantly in the 30s when at hot idle. It hasn't dropped any less than that yet in the 20k miles i've put on this car. When I rev it up, it does rise about 10 psi for every 1k rpms. When I floor it, it seems to peg above 60 the entire time so i assume thats good as well. I'm saving for a rebuild kit right now so I don't have to worry about this anymore because I like to drive my car spiritedly haha. Given what I've said, how many miles do you think are left on this engine?
Old 04-23-2007, 07:51 PM
Camaro99SS's Avatar
Sounds like you're fine. If the pump can still build 60+psi, the bypass spring or anything else in the pump is not going bad. 30psi at hot idle is also not bad for a high mileage engine. If you really wanted you could do a cam swap with a new oil pump and be fine as these engines are tough, but if I were you, just save for a rebuild and go all out.
Jason
Old 04-24-2007, 04:06 PM
Rob98LS1's Avatar
thanks for the input Camaro99SS. The plan has always been to go cam only for this car, do you think it will really put a strain too hard for this engine to handle? I could swing a new oil pump if that will help any. Would a low 230s cam be too much? That's all I'm planning on installing besides a ported t/b and some tuning. Any thoughts?
Old 04-25-2007, 12:15 AM
red02Hawk's Avatar
my oil pump was functioning fine at 163k, but i went ahead and changed it. If you already have the front cover off you might as well change the oil pump too.
Old 04-25-2007, 12:54 PM
LS100CAMSS's Avatar
At normal temps my car runs aprox. 45-50 psi, but if it idles in traffic for extended periods or I run it hard my pressure drops to 38-40. Been told this is normal, but my last ls1 car did not do this.
Old 04-25-2007, 02:36 PM
Jeff M's Avatar
I usually idle at 40-45 but it'll drop to 35 sometimes after i get on it or traffic like you stated. That makes me feel better now.
Old 04-25-2007, 02:42 PM
john563's Avatar
same here
Quick Reply: Oil pressure on high mileage car
