c-5 pick up tube in a f-body pan
Ok so I bought a motor from a c-5 and didnt think about changing the pick up tube. Long story short, motor is in the car and I have not started it yet im just wondering if the shorter c-5 pick up tube will work with the f-body pan or do I need to pull the motor out again?
Thanks
Thanks
i cant believe you got the pan on. i couldnt get my fbody pan on the bottom of a c5 motor.the pick up tube wouldnt let me put on the pan. so i dont know if it will work or not. just my 2 cents
Don't chance it. Change it out. The issue is the pickup location and height from the bottom of the pan... if it's too high, sudden g-forces will uncover the pickup and cause the pump to suck air...
there is a different part# for a camaro. go to crate engine depot .com and they have a pic of a ls6 kit for a camaro that has a oil pan kit and a dipstik and pick up.
