Cam gurus inside
Old 03-22-2007, 09:34 PM
JDPZ28's Avatar
Default Cam gurus inside
Thinking about a custom grind, kinda a combo/derivitive of the TR236 and TRak cam.
Something along the lines of 236/230 .630-.640/.590ish. Just wondering how this would run with an A4, 4k stall, 3.73's, full bolt ons, Fast 90/90, and eventually maybe some TFS heads milled for at least 11.1 compression.
Whatcha think?
Old 03-23-2007, 02:45 AM
PREDATOR-Z's Avatar
Try this 231/240 .643/.608 112+4 LSA
Old 03-23-2007, 05:35 AM
JDPZ28's Avatar
Looks interesting. Would probably LOVE the nitrous when I decide to spray it.
Old 03-23-2007, 06:35 AM
PREDATOR-Z's Avatar
Oh yeah it will, will fit stock heads/gasket, it is basically a G5X2 on Steroids.
Old 03-23-2007, 11:07 AM
JPH
JPH's Avatar
this is a real close to what i was thinking. i was thinking 232/236 .624/.590 112+4 crane cams high speed lobes myself.
Old 03-23-2007, 11:34 AM
JDPZ28's Avatar
you think it would have more area under the curve than the X2? I had that cam in my last Z28 and liked it. Put down 405rwhp with bolt ons.
original post was a reverse split, as I was thinking about trying something different. Seems everyone nowadays is set on a traditional split. From what I've seen the reverses like the TR236, MTI (X1?), etc. have usually produced good numbers due to the LSx motors being intake restricted. Any opinions on a custom reverse split that will clear stock heads and still make nice power/
Old 03-23-2007, 12:09 PM
PREDATOR-Z's Avatar
Yes it will due to the lsk intake lobe.
Regarding the reverse split, this is my personal views;
https://ls1tech.com/forums/generation-iii-internal-engine/652563-reverse-torquer-cam-other-side-coin.html
Old 03-23-2007, 05:15 PM
JDPZ28's Avatar
https://ls1tech.com/forums/showthread.php?t=652563
Thanks.
That was actually the thread that got me thinking about getting a reverse split a few weeks ago.
The cam you spec'd out above, who would you recommend I contact about grinding it for me? I was thinking TR--->
Old 03-24-2007, 12:23 AM
PREDATOR-Z's Avatar
Any vendor that carries comp cam grinds. TR is a good place, let me know if you're serious, i'll give the full specs with lobes.
Old 03-24-2007, 01:12 AM
N4cer's Avatar
Why not just call Comp directly?
Old 03-24-2007, 01:49 AM
PREDATOR-Z's Avatar
That too
Old 03-24-2007, 10:46 AM
NoMoreFWD's Avatar
Because it will cost about $100 more than a vendor giving a decent discount.
Old 03-24-2007, 05:48 PM
JDPZ28's Avatar
Actually, just doing a bit of research, but why choose this cam over a MS4(239/242, .649"/.609" 111lsa) ?
Old 03-24-2007, 09:16 PM
N4cer's Avatar
Comp charges $400. What vendor is selling new cams for $300?
Old 03-24-2007, 09:23 PM
MonteCarloNOS's Avatar
Comp charges 400 for a custom cam?
Old 03-24-2007, 09:41 PM
NoMoreFWD's Avatar
According to Comp's web site, all the LS1 cams listed are $473.44. Speed Engineering has the best prices for custom cams that I have found. PM them if your in the market. You will be pleasantly surprised.
Old 03-24-2007, 10:54 PM
N4cer's Avatar
Ahh they must've raised the prices. Call them to make sure, as with all companies.
Old 03-25-2007, 12:10 AM
PREDATOR-Z's Avatar
For 1, the 231/240 will clear at safe margins, not pushing the limits, DCR would be higher, and sligthly better under curve area. More streetable (although tuned the MS4 does well)
Peak HP will be slightly less than MS4
Old 03-25-2007, 09:17 AM
JDPZ28's Avatar
Gotcha. If you don't mind I would like the specs if you can find the time to PM them to me.
Thanks,
JP
Old 03-25-2007, 10:41 AM
PREDATOR-Z's Avatar
PM'd you
