Z06 Cam
Old 03-22-2007, 10:38 PM
2002TAWS6Pontiac's Avatar
Default Z06 Cam
I have a 02 WS6 stock with just exhaust and intake, if i took my buddys 03' Z06 cam and put it into my LS1 how much gain are we looking at any guesses?
Old 03-22-2007, 10:40 PM
headed-ws6's Avatar
From what I have seen and heard you might get 20 rwhp if you get a decent tune on it not bad if you get it for free or cheap. ooo and youll need to get ls6 valvesprings as well.
Old 03-22-2007, 10:43 PM
chummmma's Avatar
i havent dynoed my car yet but when i went from ls6 intake/vararam 12.6 i added a z06 cam and a catback (FWIW) i dropped to a 12.2 a very solid gain and the car is deff. faster all around. gained about 2 mph in the 1/4. I havent tuned the car yet either. I threw the cam in because the front main seal was leaking and had to pull the cover off so i figured i would just throw it in.
Old 03-23-2007, 06:54 AM
mcamarols1's Avatar
one of my friends had that cam, and all the bolt ons, car made 350whp & 350wtq(m6), and he ran a 12.4 in the 1/4, then his 10bolt said KABOOM, he now has a bigger stronger cam. just my .02
Old 03-23-2007, 03:43 PM
did his rear go kaboom after he added drag radials or just on street tires?
Old 03-23-2007, 06:38 PM
MannyZ28's Avatar
If you're gonna go through the trouble of switching cams, you might as well get something bigger in there, unless you're going for more power with stealth from a stock cam. You still have to buy springs anyways, and pushrods don't cost that much. A new cam is "only" 390 dollars anyways.
Old 03-23-2007, 08:11 PM
Chris81's Avatar
I like mine, it runs very well (see sig, thats 11.6x @ 118 @ sea level for comparison).
Mine picked up 20 rwhp over the stock cam peak, but at 6000 rpm where the stock cam is done the LS6 is made over 40 rwhp more. At the track after the launch it never sees under 5000 rpm with 26 inch tires and 4.10's.. so it works very well in that respect. You won't notice much of a difference under 4000 rpm from the stock cam unfortunately.
I say do it if you can do it cheap, otherwise go bigger.
Old 03-23-2007, 09:58 PM
I am looking to be more stealth and a stock look and sound. i also wanna keep the car comfortable as a dailey driver or be able to drive a distance without worrying about breaking something.
Old 03-23-2007, 10:10 PM
Adrenaline_SS's Avatar
Look into the CheaTR cam, by Thunder Racing
It supposedly has everything your looking for; stock sound and drivability but has significantly more HP (~30 RWHP) on stock manifolds- even more if you decide on headers later
Old 03-23-2007, 10:26 PM
Ryan02SS's Avatar
I got a great deal on one back in 02 and ran it along with LS6 valvesprings and stock pushrods for about 5K miles. I had Lid,ASP,PTB LT's ORY SLP DD, stock 02 heads. Made 366rwhp @ 351rwtq untuned and 376rwhp @ 361rwtq tuned. Car ran really good, especially above 4500rpms and idled like stock. It was a definate increase over stock.
Old 03-23-2007, 10:31 PM
SSmoky01's Avatar
I just bought one for 150 dollars and will be installing it soon. Will 7.400 pushrod's work on this cam??? Sorry to high jack your thread.
Old 03-23-2007, 10:38 PM
Chris81's Avatar
The only problem with that cam is it has a good amount of lift, so it wouldn't be a "swap it and forget" type of cam. The springs would definitely need to be watched like any other higher lift camshaft if it is daily driven.
Old 04-01-2007, 10:06 PM
mcamarols1's Avatar
yup, he was on ET streets did a burn out, went to launch and only moved about 3feet he was on a ls6 clutch too
