Patriot Gold Dual Springs
Old 03-24-2007, 12:15 AM
little_chewy_69's Avatar
Default Patriot Gold Dual Springs
i have been searching threads and the net to try and find the specs on these springs but cannot find them does anyone know them? And how do they compare to the comp 921's im on a budget. Need them for TR trak cam.
Old 03-24-2007, 12:39 AM
eamador11's Avatar
excellent springs. holds up to .650 lift. i have them
Old 03-24-2007, 12:45 AM
00T\A's Avatar
Pm Gunner @ Patriot i think they have a new spring that is supposed to handle th LSK lobes better.
Old 03-24-2007, 07:22 AM
Redlinez's Avatar
Great springs, quite a few guys have run 650 lift for years with no problems. You always have a failure percentage, but I'd say it's quite low. I'll be going with PRC duals or Patriots.
Old 03-24-2007, 07:46 AM
Studytime's Avatar
Man, you're setting yourself of for trouble yet again. You need the patriot extreme dual coil springs. Yes, the regular duals can handle .650" lift, but they will not provide enough spring pressure.
There have acually been people install the regular duals and still float valves with the exact cam you have. Stepping up to the extreme dual coil springs solved their problems.
Good luck!
Ben T.
Old 03-24-2007, 06:52 PM
GuitsBoy's Avatar
As everyone already stated, the patriot golds are great springs, however for LSK lobes, I would step it up to the extreme. Alternately since Im running XE-R lobes, ill stick with the regular gold duals when its time to replace em.
Old 03-24-2007, 07:14 PM
stealth71's Avatar
patriot gold extreme dual coil springs
The max lift is .660", seat pressure 155 lbs., 410 lbs. open.
1.090" on the coil bind and the kit is $279.50.
This is what I was told.
Old 03-24-2007, 07:41 PM
black01_WS6's Avatar
like others have said get the extreme set up for the lsk lobes. It is not much more money wise, so it should be a no brainer.
