Looking to build a 400rwhp ls1.
Old 03-24-2007, 11:37 AM
romanss's Avatar
Default Looking to build a 400rwhp ls1.
I have a freind that is looking to build a 400 rwhp 02 vette.
Here are the conditions:
1) emissions freindly.
2) reliable.
3) N/A
4) heads and cam.
5) stealth (no cam lope)
Do you guys have any experience with a combo like this? Or any reccomendations?
Thanks,
Roman
Old 03-24-2007, 11:52 AM
PREDATOR-Z's Avatar
Custom cam 210/224, .555/.567 115+1 LSA (XE lobes)
Halltech air filter unit
Ported TB
25% underdrive pulley
X pipe and Magnaflow catback
Tuning
I'm at 368rwhp (A4), all I need is a nice set of 61cc small runner heads with good midflow to push it at or close to 400rwhp.
That cam meets all the requirements, using 918's, -13* overlap so very emmision friendly, no lope (I had to get an aftermarket catback to make me feel I wasn't on stock cam, that got me a whole 8rwhp)
Old 03-24-2007, 07:46 PM
black01_WS6's Avatar
talk to patric G on the boards. I knwo that he had a cam made that was similar to a cheater cam but had like 641 lift and put down just over 400 rwhp cam only.
Old 03-24-2007, 08:11 PM
1slowls1's Avatar
205cc AFR's
224/224 581 on a 112
Patriot gold 650 lift double spring kit
possibly some injectors just to be safe since your in there
port the t/b
Kooks headers with kooks y-pipe and cats with magnaflow exh.
and a tune should be well over 400
very streetable and reliable maybe even smaller on the cam like a 222 on a 114 or something
Old 03-23-2008, 09:09 PM
hammertime's Avatar
Originally Posted by 1slowls1
205cc AFR's
port the t/b
While this would handily surpass 400rwhp, it won't be stealthy at all. The 224/224 112 cam has 0 overlap at .050" lift and will have some chop to it. Even a 222/222 114 has -6 overlap, and would be noticeable.
Also worth noting, I don't see Longtube headers mentioned in either of the first two posts. The 224/224 cams would not work well with stock manifolds.
Old 03-24-2008, 06:18 AM
PREDATOR-Z's Avatar
digging up Gost threads
Quick Reply: Looking to build a 400rwhp ls1.
