1.8 rocker hp gain, worth getting them?
Old 03-26-2007, 12:44 AM
whitedevil's Avatar
Default 1.8 rocker hp gain, worth getting them?
Well, I really dont want to go through the trouble of installing a new cam in my car, and I drive my car every day, and make a rather long commute to work, and dont have the time to put the car down.
My friend has an LT1 camaro, and would often hit a 14 flat at the strip. He installed 1.7's on his car, and it seemed to wake it up a lot, after a few runs, he did 13.6 if I remember correctly.
Will going to 1.8's be a decent mod for the money? What is the increase on average, with a stock ls1 cam? Will I need new push rods, and valve springs? Will this be ok to spray with, and lastly, what set would be best to look into getting?
Thanks every one.
Old 03-26-2007, 05:09 AM
vettenuts's Avatar
You will definitely need new springs. The 918's will be the cheapest and easiest to install since you can keep all your other parts (retainers, etc.). I think the Crane rockers are the better choice for this. The kit comes with all the parts, including pushrods which are shorter than stock (7.250"). A lot of guys will suggest a cam instead, but if you don't want to open the motor this may be a good option for you. If you do it, make sure you post your results as a lot of people ask about this.
Old 03-26-2007, 05:51 AM
Justin00SS's Avatar
Is the search broke?
I know I've made two threads on this and another guy with a white formula got good gains and he always posts in them.
Old 03-26-2007, 05:54 AM
whitedevil's Avatar
Thanks for the info. I am going to check it out.
