Do any shops market small cams anymore? why NOT? - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 03-25-2007, 05:48 AM   #21
ЯєŧąяĐ Єlímíиąŧ°я Ö
orangeapeel's Avatar
I would normally just steer clear of this thread, but I will also note that I have climbed the cam ladder and it progressively sucked harder towards the top.
2002: 222/226 ran on stock tune for about a year, got it tuned and it seemed to have a tad more.
2002: 224/224 ran with the 222/226 cam tune and it ran great all day all kinds of weather.
2004: 228/232 had a surge issue here and there
2005: 236/236 had low rpm bucking and surging, but I was still willing to tolerate it.
2005 - Current: 244/248 bucks like a champion bull, surges on hot days in traffic, burned up a clutch just to get it to go, worthless until 4k, but sounds cool.
This was all on the stock gears. I don't drive it but every now and again though. It is getting close to being weekend warrior and track car only (which I don't want). I will take it to work right now just to have some oil move through it. Still undecided on a rear end, but it will consist of a cam swap...going smaller I can tell you that.
orangeapeel is offline   Reply With Quote
Old 03-25-2007, 08:27 AM   #22
Senior Member
Country Boy's Avatar
I think some of us did learn the hard way. I started with the G5X2, went to the G5X? (this was one NASTY cam... felt like a drag car and would not do anything but buck and surge below 3k, but after that it would flat ******* fly!) , then to the G5X3 (I liked this one) and then went to the LPE GT2-3
Country Boy is offline   Reply With Quote
Old 03-25-2007, 10:17 AM   #23
Moderator
jimmyblue's Avatar
Selling in the crowded automotive aftermarket seems to need
vendors to get folks to let go of rationality and buy based on
excitement / impulse. Common sense is not part of the picture.
Hard to get someone to plunk down $350 for "It's not the best,
biggest or baddest but it's sensible improvement" when your
comp is saying "only $349.95 and you will kick all ***" (fine print
says "may require some tuning, 5.83 gears and a 9000RPPM
converter").
Sex sells. Just so happens the little bit about giving or receiving
(and side effects) is left to the buyer's imagination.
Me, 224/224 on a 116, still on the shelf. Used. I'm nobody's
he-floozy.
jimmyblue is offline   Reply With Quote
Old 03-25-2007, 10:37 AM   #24
Toxic Texan's Avatar
Still running the 224/224 C1 with Patriot heads and making 400rwhp, so no big cam for me.
Toxic Texan is offline   Reply With Quote
Old 03-25-2007, 10:52 AM   #25
Im Feelin Blue
2MuchRiceMakesMeSick's Avatar
ive been there done that....big cam is not the way to make a car move
I have a Z06 cam now and Im finally going to start putting the turbos on
2MuchRiceMakesMeSick is offline   Reply With Quote
Old 03-26-2007, 09:12 AM   #26
Firehawk Director
epic's Avatar
Still rockin' the TR224 in my Firehawk..
Car is an absolute blast to daily drive when the weather is nice in Chicago.
epic is offline   Reply With Quote
Old 03-26-2007, 10:35 AM   #27
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
As has been stated already. You have the crowd who thinks bigger is better. If 230 is good, then 240 must be better. After all it is bigger, so its going to make more power, right? I'll use the T-Rex as an example. Q: What was the impetus for that cam? A: The biggest possible cam you could fit into a motor plain and simple. That isn't to knock TR for building it, they built it to fit a segment of the market who feels bigger has to be better. They gave the market exactly what it wanted. Even if what hey wanted isn't the best choice for them. I commend them for it. After all if the stupid people want it, and you try to educate them, and they still come back wanting a BIG cam, give them what they want....
Patrick is right tuning is the key. I saw the Aussie guys in '03 tune BIG cams to run in SD. We're just getting to where they were several years ago. Tuning software is getting beter. Now, the skill of the tuners just needs to catch up.
But, it all comes down to combination. Folks never want to hear that. Let me give you an example. Going back to "old school" (mid-late 80's).
Everyone who put together a motor seemed like they either had to go with a Comp 292H (244/244 110+4) or if you were going crazy, then you stuck in a 305H (253/253 110+4). These were stock headed 355's to 406's. Sometimes with ported iron heads, but often times you were just lucky to have unported heads and 2.02/1.60 valves. Of course for anyone who was around GenI stuff, you all know what "double hump" or "camel hump" heads are. For anyone else, they were the 461 casting "fuelie" heads. A setup like this made decent power. With a good setup you could have a a car that you could drive to school and run 12.20's to 11.80's. Throw a 250 shot plate on the car and run mid 10's.
Now, I didn't follow the trend. I built a 383 with a relatively small cam. It was based on a Crane HMV-278 which if memory serves me was either a 216/228 or a 222/234 cam. Same weight car (3364 for my car) as everyone else, and it ran 12.30's. I had a small stall (2200), but I ran 4.10's. The car actually had too much gear, as I'd go through the traps on the rev limiter. Car had gobs of torque, and ran down cars with much lumpier cams, better heads, etc... It was all in the fact they had not thought about the combo. It was all about bigger must be better. I outran numerous cars that on paper I shouldn't have.
Another example. Everyone had to have an 850 double pumper. I ran a 750 vaccum secondary with a metering block conversion kit so I could jet the back barrels, and to control the "hit" from the back two barrels). I tuned the carb so that with my small stall (which was just a bit too small for my cam), and with a #25 squirter in the front that the car had just the least ammount of bog in it. This allowed me to run CHEAP tires on the car. My daily driver tires were Road Hugger Radial GT's that my buddy gave me off his car. They were like 215/75/15's (car ran 12.50's to 12.70's on them). I had a set of M&H's that a buddy witha Mustang said wouldn't hook. I mounted them on spare rims, and ran them for 2 more years. I just carried my "carb kit" in the center console. So, when I swapped tires I just changed out the squirter (to a #35). Then the car got VERY throttle resposive. Had I gone with conventional wisdom and put an 850 on the car it would have been over-carb'd, it probably would have been soggy on throttle responsiveness, etc...
Half the folks on here just want to keep adding lobe, spreading LSA, and advancing the cam in the hopes it will make power. If folks spent half as much time thinking about the end goal of their combo, rahter than who makes the best looking airlid, or whose Y pipe is going to get them .0001HP then there would be a lot more cars out there who were making big power.
We run a fairly big stick in Tommy's car, but it is purpose built for one reason, so that is the cam that does what it needs to do. I could drive a car with deep gears and a big lope every day. But I know a lot of folks who wouldn't enjoy it at all. So, it also comes down to personal preference.
But, I think it is funny to lay some of the graphs over one another and you see a car with 400 HP, and the area under the curve and the average power is 100x that of a car making 450 RWHP that has a little ski slope at the end of the graph basically. But, those big numbers are what sell packages. People don't look athe whole graph just like they only look at peak flow numbers froma flow bench. Who cars about port volume or midlift....
J-Rod is offline   Reply With Quote
Old 03-26-2007, 01:30 PM   #28
gator's 99TA's Avatar
My main concern in starting this thread is my opinion (and many others) the smaller 221 to 224 cams can ACTUALLY make good usuable power and go fast. so MANY cars were going 11s n/a and 10s on spray on a daily driveable small cam combo. i think its ridiculous when i see these 240+ duration cammed cars in T56 cars going 12s
gator's 99TA is offline   Reply With Quote
Old 03-26-2007, 02:27 PM   #29
LS1Tech Co-Founder
Nine Ball's Avatar
Sadly, I feel that too many newer LSX enthusiasts that just joined the game are influenced by peak dyno numbers and are forgetting that it is all about having the highest average horsepower throughout the racing RPM range. That means you want a nice broad HP curve across your racing powerband, not just some goofy looking high HP spike at the shift point.
We were running 11s on motor back in 1999 with 221/221 cams, full weight cars with zero weight reduction, on drag radials, hypertech tuning, with ported heads that didn't even clear 300 cfm. It is sad to see how many cars today run slower than that and have HUGE cams and crappy drivability.
Time to quit dyno racing and spend more time at the track.
Nine Ball is offline   Reply With Quote
Old 03-26-2007, 02:31 PM   #30
Kleeborp the ModeratorÖ
MeentSS02's Avatar
Ummmm...sticky anyone?
MeentSS02 is offline   Reply With Quote
Old 03-26-2007, 02:43 PM   #31
btw to add to this post, not only can you run a small cam, run great numbers, have a great driving street car - but you can do it on cheaper valve springs. comp 918 springs are great on those small cams.
Old 03-26-2007, 03:48 PM   #32
Great thread, about time too.
Toxic -- that 224 is actually the C2 cam. Which ran 10's with the car properly set-up (N/A no less).....a LONG time ago.
Long Live the 222 C1 Hammer Cam !!!
Mirek is offline   Reply With Quote
Old 03-26-2007, 05:11 PM   #33
LS1 Tech Administrator
Patrick G's Avatar
Here's my dyno sheet with a 223/227 110LSA cam. 475 rwhp, 429 rwtq. It was good for 183mph in the standing mile.
Patrick G is offline   Reply With Quote
Old 03-26-2007, 07:30 PM   #34
Ragtop 99's Avatar
Quote:
Originally Posted by gator's 99TA
or you can throw in a 224 cam on nearly stock tuning, run 11s na, and have a great running car lol...
I ran just as fast as 228/228 as I ran with a 232/236. I probably did a better job tuning the 228 cam, but for my combo even with better tuning, I wouldn't have seen enough gain to justify the slightly worse street manners of the bigger cam.
Ragtop 99 is offline   Reply With Quote
Old 03-26-2007, 08:49 PM   #35
LS1TECH Sponsor
badpewter-z's Avatar
it is kinda sad when you think about it but ALOT of people are all about the big DYNO number and then the car has nothing on the street where its mainly used. there are still a few here that do get it though and strive to teach the new comers its more about "under the curve " power that you want. im still on the smaller side and love it with no surges/bucks/ect. all my setups so far have run great. TR230/224- made great power, ran hard at the track. got 26+mpg still lol. 230/228 on 112 same thing drives awsome with no issues, and backs it up at the track and street . espically when 80% of the cars usage is the street . AFR desigened there heads to work with smaller cams , look what that 224/228 "baby" cam did. ill take smaller anyday to a monster that wont be up to par under the curve on the street. now whe you add more cubes it gets a tad different
badpewter-z is offline   Reply With Quote
Old 03-26-2007, 09:41 PM   #36
LS1IMPULSE's Avatar
I think it has alot to do with people not wanting to spend big bucks on heads to match there smaller cam. I would take a 22X/AFR's over my F14 anyday...but the the cost difference between them is huge.
LS1IMPULSE is offline   Reply With Quote
Old 03-26-2007, 10:15 PM   #37
Quote:
that looks like mt. everest lol
ls1luver is offline   Reply With Quote
Old 03-26-2007, 10:27 PM   #38
Yep, enough said for the small cam.
1989GTA is offline   Reply With Quote
Old 03-27-2007, 07:05 AM   #39
gollum's Avatar
Here's SLP's new L92 packaged 402 with small 224/228, 113lsa cam. This type of motor would be perfect with a stock 3:42 geared car.
http://www.slponline.com/coming_soon_51016.asp
gollum is offline   Reply With Quote
Old 03-27-2007, 08:15 AM   #40
Hmmm... Maybe that's why my TSP 224R didn't have a cool name like "The Lizard", or "Devil Stick", or "Mighty Mouse"...
kilrb is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Can someone tell me about where this cam will peak at? LilJayV10 Generation III Internal Engine 8 10-23-2015 08:02 PM
[SOLD] Ford 30# Injectors - Red Tops ghettocruiser Parts Classifieds 5 06-10-2015 11:11 AM
403ci stroker dyno results...long, but a good read gtodoug Dynamometer Results & Comparisons 10 09-07-2008 04:29 PM
boost vs cubes ayousef Forced Induction 27 08-10-2008 08:39 PM
L92 H/C package results with cam specs and dyno results Spinmonster Generation IV Internal Engine 11 07-18-2008 09:34 PM
Tags
big, boy, cam, car, country, custom, fl, forums, grind, lifts, posts, rim, shaft, shops, smallcams, tampa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
