View Poll Results: Which cam should I go with?
TSP 228r
28
34.57%
TSP Torquer V.2
53
65.43%
Voters: 81. You may not vote on this poll
Final cam decision, please vote!
Old 04-06-2007, 10:30 PM
Tainted's Avatar
Exclamation Final cam decision, please vote!
Ok folks I got it narrowed down to 2 cams. I've filtered out all the others and only intrested in these 2. Tell me what one you would go with and WHY!!
TSP 228R
228/228 .588/.588 112lsa
OR
TSP Torquer v.2
232/234 .595/.595 112lsa
This car will more than likely get a set of ported LS6 heads with all the goodies and I WILL NOT go over a 3200 stall! Driveability is a huge factor, I can't have it not finding an idle and giving me constant problems. Bryan @ pcmforless will be doing the tune since theres literally no one for at least 2 hours around me that can dyno tune. I will also be passing NC emissions which is the pcm check
***Does anyone think the torquer 2 will be to big for a DD on a 3200 stall and mail-order tune? seriously folks put some input in 8 votes and no info
Old 04-06-2007, 11:17 PM
Tainted's Avatar
dont forget to say WHY you chose what you did folks!
Old 04-07-2007, 01:09 AM
LS1IMPULSE's Avatar
I chose the T2 becuase you didnt have any FMS cams in the poll, F14 FTW !!!
Old 04-07-2007, 01:10 AM
Tainted's Avatar
looks like the same cam pretty much, you think ill be fine with a 3200 stall with it as a DD?
Old 04-07-2007, 01:11 AM
00slowredz's Avatar
i said the torquer2 because i know people run a lot bigger cams in their dd's, its shown damn good results, and you're gonna have a 3200 stall so i think you'll be fine....
as far as drivability though, the tune can make or break you about as much as a stall can
Old 04-07-2007, 01:12 AM
Tainted's Avatar
I hope bryan can do a good mail tune then. the only thing I dont wanan do with the v2 is spin it to the moon its gonan be shifting at about 6300 tops
Old 04-07-2007, 01:15 AM
00slowredz's Avatar
6300!?!?! these motors love to be spun high man, you just gotta do the supporting mods when you do the cam. my cam's duration is SMALL compared to the torquer 2 and its still pulling when i shift at 6600
Tainted's Avatar
well im prolly gonna sue stock rods and pistons as well as lifters but im gonna use the arp rod bolts so i dunno how well the stock rods and lifters will hold up
Old 04-07-2007, 01:22 AM
CaliboyTA's Avatar
im a daily driver and i have a torquer 2 and its great
Old 04-07-2007, 01:24 AM
Tainted's Avatar
what are you shifting at?
Old 04-07-2007, 01:27 AM
CaliboyTA's Avatar
bump the redline to 7k but on the dyno graph, peak hp is 6300
Old 04-07-2007, 01:28 AM
Tainted's Avatar
woah 7k is way to much i really really dont wanna push it past 6400 at the most if this new motor pops or something goes wrong game over for me
Old 04-07-2007, 01:30 AM
CaliboyTA's Avatar
well the peak hp is 6300, i normally shift where the stock redline is, but if i want to i could go to 7k's, thats where the tuner put the limiter
00slowredz's Avatar
just spend a little more money and add pushrods and ls7 lifters to your list....its worth it man. u can pick up a set of pushrods for a little over $100 and i got my ls7 lifters for $110 (shipped)
you ARE gonna do dual valvesprings right!?!?! and oil pump, timing chain, ti retainers, etc...
Old 04-07-2007, 01:32 AM
Tainted's Avatar
oh yea man im getting the heads/cam package from TSP. i think ill jsut do the beehive springs tho since the torquers lift isnt (in my eyes) enough to make me need the dual springs. im even getting some 1.7 RR's
Old 04-07-2007, 01:33 AM
CaliboyTA's Avatar
exactly. thats what i've done: ls7 lifter, pushrod, oil pump timign chain etc. Extra security, i sure as hell don't want to do it again.
00slowredz's Avatar
its all in what you think you need but i'd rather have dual valvesprings and NOT need them, then hear KABOOM and wish i woulda just spent the money in the first place
Old 04-07-2007, 01:35 AM
00slowredz's Avatar
i did...
comp dual valvesprings
ti retainers
seals, seats, locks etc..
ls6 ported oil pump
ls2 timing chain
chromo pushrods
ls7 lifters....and i think thats all
Old 04-07-2007, 01:38 AM
Tainted's Avatar
I can get ls7 lifters cheap that aint a problem and i suppose i could upgrade the springs if yall see a need for them. if the peak is at 6300 though why keep it spinning?
Old 04-07-2007, 01:46 AM
LS1IMPULSE's Avatar
Same at .050 but not the same cam, although pretty close, I think I just have a thing for FMS cams
