What is the quietest, tightest and most efficient LS1 heads/cam/stall combination?
I have a 2002 LS1 Z28 with the A4 and all of the basic bolt-ons less a brand-new SLP dual dual catback and Kooks 1 3/4" lontubes with high flow cats--both are waiting to be installed. This car will always be a daily driver and will see the dragstrip around three times a year.
I want a quiet cam with a lot of low-end torque matched with the highest flowing ported heads. I also want the tightest and most efficient 4L60E torque converter that will match the power range of this heads and cam combination. Basically, I want the car to drive like a factory-stalled, external bolt-on car, but with enough rear wheel horsepower to get me consistent low 11's in hot and humid weather. I also don't want to sacrifice too much fuel economy. Thanks in advance for the suggestions.
Originally Posted by 4mula
to run low 11s youre not going to sound anywhere near stock unless you spray away.
Thanks for the suggestion on the CheaTR cam. I just read TR's description of it and it does sound exactly like the cam that I would want. Their package added nearly 60 horsepower to a car that had a factory exhaust so I can only imagine what the gains would be if it was installed on a car that had a full aftermarket exhaust with the FAST 90mm intake and Nick Williams throttle body.
LS1 Tech Administrator
Actually, the CheaTR cam, while excellent, excels with stock exhaust manifolds. I have come up with a custom version that has the same overlap as the CheaTR, but is more appropriate for use with headers and will make more power under the curve:
218/224 .605/.600 114LSA +2
It's still a custom cam at this point, but it rocks with headers. The Vette guys love it!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
1 Post
I was looking into the same thing Damon. Patrick G def knows he stuff I seen he has had 4 or more LS1 cammed cars. I'm using some of his topics/suggestions for my crab
If you are going to use headers and a high flow cat-back I would not recommend the CheeTr. It is designed for stock manifolds. Look at the MTI Stealths or the TS Old Man cam (very poor marketing name for the cam!)
Originally Posted by 01vetter
If you are going to use headers and a high flow cat-back I would not recommend the CheeTR. It is designed for stock manifolds. Look at the MTI Stealths or the TS Old Man cam (very poor marketing name for the cam!)
The MTI stealth II likes high compression, I've used that one in 3 different setup configuration. But knowing what I know now, one can improve on it.
Patrick,
This cam in an LS1 with Ported TB, LS6 Intake, and LT headers. Any guestimate on RWHP?
Thanks..
Originally Posted by PREDATOR-Z
Why? It is like saying, do not put on headers on your stock motor. CheaTR is a high spinner. Although as you said "designed" with OEM manifolds doesn't mean it will perform poorly with a set of headers.
I am currently running the Stealth II with a stock converter. I love it. I wanted more power, so AFR 205's are being installed right now. Im getting ready to order a vigi 3200. BTW, I dynoed 380rwhp and 365 rwtq with the stealth II and full bolt ons.
Originally Posted by WS6NIGHTMARE
Pretty good numbers. Who tuned it? Hows the driveability? Fuel economy? How well can you hear it through the Borla?
My buddy just called, and my car is ready. Heads are installed. Now I need to order the converter, which Ill probable do here in the next hour or so.
