MS4 with big money heads.
Old 04-09-2007, 01:34 PM
C5 Forever's Avatar
Default MS4 with big money heads.
I've searched, but didn't find any results of guys running MS4's with TFS,AFR, or any other high dollar head. Has anyone seen any of these set ups yet? What was the outcome?
Old 04-09-2007, 01:58 PM
Kevin Doe's Avatar
I'd like to see also, bump.
SERIALPIMP's Avatar
I would hope for at least 500 rwhp,
since others are touching 500 rwhp with those heads,
or at least that is where I would set my goal,
Old 04-09-2007, 02:16 PM
C5 Forever's Avatar
I ask because it seems those 500 set ups are running 230 something cams. A lot of people have said you need the bigger sticks for cheaper heads, and smaller ones for really good heads.
Old 04-09-2007, 02:29 PM
headed-ws6's Avatar
I would say with a nice set of plan Ls6 heads and a decent tune you could see 480 rwhp easy. And everyone knows there is way better then that
Old 04-09-2007, 06:10 PM
C5 Forever's Avatar
I just realized how big the Vindicator from Vengeance is, MS4 is on the same level. It should produce really good power.
Old 04-23-2007, 03:22 PM
C5 Forever's Avatar
Still waiting to hear from those guys with AFR's or TFS heads...
Old 04-23-2007, 03:31 PM
ArrestMeRed99Z28's Avatar
Try posting this in the Dyno section, maybe you'll get a better responce there?
AJ
Old 04-23-2007, 04:26 PM
slow trap's Avatar
true,there are a few 500 rw cars with similar sized cams but the majority of the setups even with good heads is in the 470-480 range.don't get caught up in the "my car has 500 rw rage" because it may not actually have 500 rw on everyones dynojet.search for similar setups with an ms3 then add probably 8-12 rw with the lsk lobe ms4.
