gm head gasket kit question?
Old 04-10-2007, 12:36 AM
Daredevil_TA's Avatar
Default gm head gasket kit question?
Im doing a heads an cam swap soon an i was wondering if this would be a good kit to buy, im kind of a newbie so any help would be apprciated, anyway its the gasket kit from texas-speed heres the link
http://www.texas-speed.com/shop/item...id=87&catid=36
does anyone know what the head gasket thickness is that comes in this kit, i need .040 for my CR? thanx again
Old 04-10-2007, 02:14 AM
LS1C5Vette's Avatar
its the stock thickness which I think IS the .040, thats the kit im getting but with the MLS gaskets instead
Old 04-10-2007, 03:13 AM
PREDATOR-Z's Avatar
This kit and it is .052>.054 compressed thickness.
Basic Heads & Camshaft Bolt & Gasket Kit
Item#:
25-HCKIT
GM LS1 Graphite Set
GM Set for Pre-2004 Blocks, Long and Short Bolts
Your Price
$149.99
There is no GM gasket in .040 thickness.
What is your H/C combo you're planning on?
Old 04-10-2007, 09:00 AM
im going with a LPE GT2-3 and a set of Patriot stg 1. ls6 cylinder heads. I asked the guys at patriot that i wanted to bump up my CR and they told me to use the gm graphite gaskets with .040 thickness, i was told it'd give me a CR of 10.7:1, i find this odd now that you tell me they don't make that thickness
Old 04-10-2007, 09:52 AM
LS1IMPULSE's Avatar
If you didnt already order the heads you could have them milled. Either way I would give TSP a call and find out what all comes in that package becuase Patriot will send you all the head bolts you need for $20+ shipping, and you can get GM MLS gaskets from Thunder Racing for $23 each.
Old 04-10-2007, 11:39 AM
PREDATOR-Z's Avatar
I've used both GM type, graphite and MLS, .052>.056 is the range compressed.
Mill the heads to 61cc (.015 mill) and use the MLS. IMO
Old 04-10-2007, 01:56 PM
well ive already ordered the heads about a week ago, should i call patriot back an explain my situation?
Old 04-10-2007, 02:02 PM
LS1IMPULSE's Avatar
Sure, or order the Cometic .040 gaskets. They will be more pricey than GM's though
Old 04-10-2007, 02:11 PM
Well i sent gunnar an email hopefully he'll get back to me here soon, if not then i'll call-I've never done a H/c swap before, is it better to buy one of those gasket kits or is that just a waste of money? what would you guys recommend?
Old 04-10-2007, 02:27 PM
okay gunnar is telling me that the 99-00 gm graphite gaskets are .041 compressed? an predator says they are .052-.056 compressed-so whats the deal?
Old 04-10-2007, 03:13 PM
LS1IMPULSE's Avatar
call another vendor, maybe TR? Predator might be going on his expirience (and his sig says he has an '01) so gunnar is probably correct, but it wouldn't hurt to make sure form another vendor.
I would call TSP to find out what all is included in their package. I bought mine from WS6store, TSP had a good price for the cam kit I wanted but shipping came out to be like $35 after I added into the shopping cart so I bought from a different vendor
Old 04-10-2007, 03:17 PM
C5 Forever's Avatar
Old 04-10-2007, 05:22 PM
BAD2000TA's Avatar
Predator knows his stuff. The factory does not have .041 compressed gaskets. Stock is between .052 and .056. I think I read somewhere that the GM MLS gaskets crush to .054. I used the GM MLS on my 2001 Trans Am. No problems at all. They are reliable and cheaper than the Cometic. Don't even sweat it.
Old 04-10-2007, 08:16 PM
quick346's Avatar
yeah i just bought the GM MLS gaskets from summit. 30 bucks for a pair.
seems to cheap to be true. but i got them today .same one's that came of my 04 ls1 that i sprayed 150 on a ton of times with no problems.
Old 04-10-2007, 08:31 PM
ExceSSive's Avatar
I bought the cometics, Thunder sells the GM gaskets I think for $20.00 or so
Old 04-10-2007, 10:00 PM
Well the thing is i would go with the gm gaskets if i wanted to stick with the stock CR, but I want to bump it up a little bit so i want a thinner gasket, so far i dont think ive seen a kit with the quench that im looking for
Old 04-10-2007, 11:32 PM
seawolf18's Avatar
Mr. gasket makes a .042 compressed thickness gasket for around $20.00 a piece.
Old 04-11-2007, 12:35 AM
PREDATOR-Z's Avatar
If that was true then none of use would ever buy Cometics
out of the dozen+ time I've swapped those graphites they measured .053 & .054 with my caliper (digital)
Old 04-11-2007, 08:58 AM
1CAMWNDR's Avatar
Do it right. Get the Cometics. Are the Cometics the same for all LS1 years, or are they different '98-'00 and '01-'02 like the GMs??
Old 04-11-2007, 10:13 AM
does cometic make a heads and cam swap gasket kit? if not then what other gaskets do i need besides the ones for the heads? thanx again predator
