Meth injection on high compression N/A Motor??
Old 04-15-2007, 03:03 PM
SPRAYED 01's Avatar
Default Meth injection on high compression N/A Motor??
Just had a thought. Im going to be in the market for a new motor for a winter project. I want to try to squeeze every last hp out of it n/a. What are everyones thought on using meth injection in order to use high compression and still run it on 93 octane. I was thinking 402-408 with about 13:1.
Alex
Old 04-15-2007, 03:06 PM
brad8266's Avatar
I have heard of people doing that with success. I personally think its a waste to do, just bump down the CR a little bit so you can run 93 with no problems. Besides dont you run n2o? Just jet up a tiny bit more, it isnt worth a meth kit just to squeeze a litte bit more out.
FWIW i run about 12:1 on 93 with no problems.
Old 04-15-2007, 03:24 PM
lynx853's Avatar
you can get the meth kit and just advance the timing more instead of going for higher compression
Old 04-15-2007, 03:25 PM
brad8266's Avatar
You will only make power up to a certain point by advancing the timing on these engine. After that point you can keep advancing but you wont gain anything.
Old 04-15-2007, 03:30 PM
SPRAYED 01's Avatar
Im currently running n20 but i want to switch it up a little on my next build and try an all motor setup. Hoping for low 10s full weight.
Quick Reply: Meth injection on high compression N/A Motor??
