The TSP 5.3 Heads stage 2.5 and MS3 camshaft for a 01 z06?
Old 04-17-2007, 01:25 AM
Wants an LS1's Avatar
Default The TSP 5.3 Heads stage 2.5 and MS3 camshaft for a 01 z06?
Looking to put this combo on a 01 z06 and was wondering if anyone has any track times with it and what theyve gotten out of it? Are the 5.3 heads a good choice since i wish to use spray to get myself in the nines if thats possible on stock block? thanks.
Old 04-17-2007, 05:35 AM
venom ws7's Avatar
i have a friend who has those heads with CHEATER cam in his Lumina SS (Gto)
through A4 the car 392rwhp no track times yet but i thought those great dyno numbers with MS3 in zo6 i think you can get low 11 maybe high 10 if you can drive and get traction
But 9sec will be very hard you will need alot of other stuff.
Old 04-17-2007, 06:26 AM
LS1C5Vette's Avatar
You need way way more for 9's, that head/cam set-up WILL no doubt be low-mid 11's with a tune and a GOOD driver
Old 04-17-2007, 12:15 PM
cbrtrx's Avatar
i have the same set up, with decent driving you can get mid 11's, just remember there wont be much power below 4k with that cam, the ms3 really dosnt come alive till 4500rpms
Old 04-17-2007, 01:09 PM
I would like a cam that comes on around 2500-3500 RPMS and doesnt die off shortly after....whats avalible from TSP that i could use from one of there H/C packages? Are tens even possible with ANY of there H/C packages?
Old 04-17-2007, 01:53 PM
venom ws7's Avatar
What gears do have in your car? cuz i have a alot of friends with MS3 and stock 3.42 M6 and they loving it the cam pull like a train after 3000rpm.
Then i think you should get TSP Torquer V3 231/234 .643"/.598" 111 LSA
2300-6700 RPM its a great cam with those heads.
and yes its possible with good driving there is alot of guys running 10s cam only but they have very light cars like your ZO6
Old 04-17-2007, 02:16 PM
staringback05's Avatar
hmm those heads are adding compression and your going to be throwing boost at it....you better have a very good tune...or youll have major problems.
Old 04-17-2007, 06:23 PM
venom ws7's Avatar
what boost? ^^^^^^^^^^^^^
Old 04-17-2007, 06:26 PM
cbrtrx's Avatar
the ms3 cam has a low dcr so the low end suffers unless you flycut the pistons and mill the heads down, with my ms3 and 5.3 heads my car has nothing below 4k rpms, to give you an idea from 4k to 4.7k my car picks up 100rwhp, below 4k there is little power, my last z06 had a smaller 228/232 cam and it had about 20 more hp and tq down low with about the same numbers up top
Old 04-17-2007, 07:40 PM
DONAIMIAN's Avatar
Keep in mind that the Z06's transmission is different and it basicly has the equvilant of 3.90's.
Anyways, if your looking for 9's you should really look to something else than a stock casting head. Also plan to spary in the neighborhood of a 200 shot.
Old 04-18-2007, 12:13 AM
What would you recomend?
Old 04-18-2007, 07:10 AM
DONAIMIAN's Avatar
Build everything else up first. I know its no fun, but so is getting all that power and breaking something that should of been upgraded to begin with. Make sure the clutch and the rest of the driveline could take the abuse, along with the traction for 9's. Also make sure the fuel system is up for the task of using nitrous. Keep in mind that for reliability sake I would go with atleast a forged piston.
For the heads and cam, the heads are gona come down to how much you want to spend, and the cam is gona come down to how friendly you want to car to drive.
Old 04-19-2007, 09:29 AM
erikthegoalie's Avatar
i have this combo in my ride....made 461 @ the wheels...have not hit the track yet though ( I will this weekend, 1/8th mile though)....shooting for high 11's (in the 1/4, I am still refining my 60 ft)
I will tell you that the tune is a bit of a bear. My tuner and I are still working on it...but it is getting there....as far as seat of the pants...you better hold on dude...
to be honest, I am not sure why everyone doubts the MS3 and these heads below 3k rpm....if I downshift into 2nd going say 40 and nail it....dude...I **** myself...
just be prepared to make power all the way to 7k rpms and get a good freaking tune!
Old 04-19-2007, 05:10 PM
Bill Bowling's Avatar
Talking
I have one of the early Torquer Cams 233/233 .595 .595 112 and I love it down low. I made 401HP with a A-4. I am going to be installing a set of Dart 205cc heads soon.
Good luck with what ever you get.
Bill
Quick Reply: The TSP 5.3 Heads stage 2.5 and MS3 camshaft for a 01 z06?
