Agree or not with my tuner on an over-rev?
A couple of weeks ago, I did the idiot shift of 3rd to 2nd while meaning to put it in 4th, at high {not WOT.} Rear tires chirped, fwd end nosedived before I slammed the clutch back in.
I cursed my stupidity, and drove the last mile to my destination.
Three hours later, I started the return drive home. Within a few miles, I got the dreaded SES light, which my AutoTap identified as various misfires, which I understood, and some weird **** like IAC high voltage, and high voltage MAP P0015 B Camshaft Pos Timing-Over-Retarded and others which I did not understand.
The car seem to run fine, and I have hardened push rods, so later in the day, I reset the computer. I went through the dreaded idle/relearn on a cam car. Had some misfires on AutoTap, but many fewer, and they eventually disappeared.
Last week I went on a long highway test drive with the AutoTap, no misfires at all.
HERES WHERE MY QUESTIONS START:
I happened to mention to my tuner the incident and the IAC high voltage, and high voltage MAP and other codes I could not explain.
Mr. Tuner is convinced that even though the engine idles normal and there are no misfires, I could have a bent push rod or two. He sez I should pull the valve covers and check.
I say NO because:
It's much harder to bend the Comp Cams pushrods, not likely they are bent.
Id see some evidence of bent pushrods. Loss of power, worse idle, SES codes, consistent misfire - something.
I say its paranoid to pull the valve covers.
Who's Right? What say you?
BMR Boxed Subframe Connectors {Yellow) Hotchkis Strut Tower Brace {Yellow} !CAGS Direct-Flo Airlid Holly Powershot Air Filter SLP Smooth Bellows Brian Green Ram Air System Bo White Ported Throttle Body NGK TR55-IX {Iridium} Plugs SLP Underdrive Pulley LS2 Chain 180 Thermostat TSP Ported Oil Pump Dynatech SuperMAXX Header System Comp Cams Custom Grind (220/224 .532/.535 114) Comp Cams 915 Springs and Pushrods Custom PCM programming
1.
I say NO because:
1.
Originally Posted by jinxedz
Are the valves stock?
Possibility of bent valves?
Also, If you have a bent valve, it is much more likely that you will get some kind of tick in the exhaust or pop in the intake.
No codes.
No tick.
Originally Posted by fnbrowning
Usually the valve is much stronger than the pushrod, so the pushrod bends to absorb the shock. I would say that of all the people who bend stock pushrods due to an overrev, 95% or more have no problems with the valves.
No codes.
No tick.
No codes.
No tick.
I'd still take a couple of hours to check things out if you're worried about it. Pull the coils/valve covers and look over everything (rockers, pushrods, springs, etc.) closely. If there's nothing obviously out of place, I'd button it back up - no need to disassemble rockers and check pushrods. It shouldn't take much time to give it a quick visual inspection like that. Might not be a bad time to change the plugs too with everything out of the way.
sounds like a PITA just for a 'check-up', but its the only way to know for sure
Originally Posted by brad8266
It takes a whopping 2 hours at the most to pull the PR's and check the valvesprings and reassemble. Pretty easy.
Your hardedned pushrods are stronger than your valves, once you have hardened PR's and you overrev you can easily bend valves up and it will casue the symptoms you are describing. Id be pulling the heads off if i were you after you check for a bent PR. look for a messed up valvespring too.
I had weird codes for one day, like: MAP overvoltage, IAC overvoltage, and the P0015 B Camshaft Pos Timing-Over-Retarded
All of which went away after the PCM reset.
No symptoms.
No ticking.
So the LS1TECH hive mind sez I should still pull the valve covers, huh?
You can do a leakdown test to see if you have bent valves. Bent valves will not seat correctly in the seats and leak can be determined. If something abnormal is detected, then you can proceed to yanking the heads.
That is the reason for the thread!
Are you guys suggesting leak-down tests and possible head check after one over-rev?
Have you completely read my posts?????
Well, since your original post says who's right, and you obviously care more about being smarter than your tuner, I'll go ahead and say you're right to make you happy.
Aside from that, Predator hit the nail on the head - a compression test and leakdown test would tell you all you need to know without even pulling the valvecovers. But I wouldn't worry much if you have no symptoms of a problem...
Originally Posted by hammertime
Well, since your original post says who's right, and you obviously care more about being smarter than your tuner, I'll go ahead and say you're right to make you happy....
This isn't a contest as to who's smarter.
It's a thread as to the level of {caution} {paranoia} I should apply.
Who's right means how much work the LS1TECH hive mind thinks needs to be done.
None / A Little / A Lot
It's not a game. It will determine how much time/$$ I spend.
This isn't a game
If you had the symptoms and they were physical, the car didnt fix itself. It could be the cpu is good at hiding them in your case, but my motor on stock pushrods doing the same thing as you bent 4 valves. In the end a leak down test isnt going to cost anymore than $40.00 for ease of mind.
Restricted User
my opinion is that if there is even the smallest amout of caution/paranoia in your mind, you must decide if you want to be be safe or sorry.
a....you over-reved your car.
b....your tuner suggest that your problems might be related to the mis-shift.
c.....members have also confirmed that it may in fact be a bent p/r or valve.
what else would you like everyone to say?
if there is the slightest chance you may not like the answer, please dont ask the question.
