Question about the specs on my cam....
Old 04-17-2007, 05:17 PM
LS1powerhouse02's Avatar
Default Question about the specs on my cam....
Alright i bought this cam about 2 years ago before i even did any sort of research on cams. It was a great deal so i jumped on it without thinking.
Once i started doing some research and learning more about cams i was afraid i made a mistake. Several people have told me that the LSA and the advance in the cam were hurting me. But now i have read a few threads where people are talking about how good the 110 +4 is.
The cam is a Comp Custom Grind 230/230 .591/.591 110LSA +4
Right now my rev limiter is set to 6900rpm because the car keeps pulling to there. My car doesn't even start making power until about 3500rpm it feels like. Every person i race kills me off the line and then i have to reel them in up top.
This car is my daily driver so i dont want to be spinning it up that high just to keep up with other cam only cars. So i guess i'm just wondering what ya'lls thoughts are on the cam.
Also on a side note i might have a chance to get a HPE "S" cam from a buddy soon. Should i just stick with mine or go with something else? Thanks !
Brent
Old 04-17-2007, 05:20 PM
brad8266's Avatar
Thats a good cam. What are your future goals and what mods do you plan on in the future?
Old 04-17-2007, 05:34 PM
My goals are always changing it seems like. I would love for this car to become my weekend/track car. But as of right now its my only mode of transportation. So i can't go too big. As of right now i have a headers and true duals dumped at the axle, but i am thinking about selling the true duals and going back to a catback setup just so it will be suttle enough to drive every day. I was just wondering where this cam stood as far as all around performance. Am i killing myself by having the powerband so high?
I might be getting heads and spray in the next couple of years but for the time it is going to stay cam only.
Old 04-17-2007, 05:46 PM
brad8266's Avatar
Just get your duals ran out the back, that will tame it down a lot. keep that cam until you get a set of heads, then you can match the heads and cam together.
Old 04-17-2007, 08:54 PM
67Ranger's Avatar
why not just put some more gear in the car, if you havent already? Like some 4.10s
Old 04-17-2007, 10:32 PM
SSpdDmon's Avatar
Was that cam tuned ok? I would expect a higher MPH than what you have in your sig. What kind of numbers does it make?
Old 04-18-2007, 12:43 AM
yah i was hoping to get a 9" in the car before i went and spend money on the turd 10 bolt. Right now it has the stock 3.42s in it. But i am thinking about just going ahead and putting a eaton posi and 4.10s in it anyways.
Brent
Old 04-18-2007, 12:51 AM
yah i thought it was tuned pretty good. The guy who did it for me really knows his stuff. His screen name on here is TXhorns281. I dynoed 388hp/377tq the first time but found out i was having horrible valve float due to shitty valve springs. So i installed a set of Patriot Gold Duals and could definately feel a difference in power. So i am guessing about 400hp/390tq?
I was kind of depressed with my numbers too but here is the lowdown on how the car was setup with the times it ran:
the 12.5 @ 113.7mph run was with 3.73 gears and rev limiter set at 6400rpm on Mickey Thompson ET Drag radials.
I haven't updated my new times yet but the last time i went to the track was as follows:
12.70 @ 114.9mph with the stock 3.42s back in the car (blew up the 3.73s a weekend before), on STREET TIRES, 2.1 60'. with the rev limiter at 6900rpm. I shifted 1st and 2nd gear at 6600rpm-6700rpm and then hung third and would hit the limiter just as i crossed the 1/4 mile.
Brent
Old 04-19-2007, 04:38 PM
ttt......anyone else?
Old 04-19-2007, 05:38 PM
LS1rulz's Avatar
Why do they kill you off the line? Are you launching at low RPM or something?
Old 04-19-2007, 06:31 PM
i am still on the stock 10 bolt. So i can't launch at anything really above idle.
I went to the track once with mickey thompsons but it didnt last very long. I blew my differential to pieces! 10 bolt + 6 speed + mickeys= SNAP!! But what i am more worried about is the mph i am trapping with this cam. It seems like its not getting the job done like it should, AND i'm having to spin it to 6900 to get what i am getting out of it!
Brent
Old 04-19-2007, 06:49 PM
LS1rulz's Avatar
So put on some less aggressive tires and run better times with some wheelspin. Only on the internet are 10 bolts gonna break from launching hard. Unless you run slicks, of course!
Have you put the car on a dyno? With that cam, I can't see that it would keep making progress much above 6300.
And you say a lot of guys like the 110+4. Don't forget, that has to do with the overall picture of the cam, not just the LSA and ICL. If a small cam has a small LSA and a lot of advance, it'll run like a turd.
Old 04-19-2007, 07:10 PM
02silvaZ's Avatar
some 4:10's should help
