Spun Rod Bearing
Spun Rod Bearing
I am pretty sure I have a spun rod bearing and I need advice on how to fix this issue. I have no idea what I have to do. So anything would be great full. I just rebuilt the valve train last week. After doing so I found out the sounds that was coming from the heads was actually coming from the crank case.
Well if it is indeed a spun rod bearing, you have to remove the engine & fix it.This might require a new rotating assembly,or you can replace the bearing & repair the crank..I've seen this done with out removing the engine in a truck,but a car would be easier to pull the engine.
Besides the noise,why do you think you spun a bearing? Were you having oil pressure issues?
Mileage?
Good upkeep?
Stock?
Mileage?
Good upkeep?
Stock?
Well here its. The cars been religiously oil changed with mobile 5w30. K&N oil filters. I was coming into work one day and heard a ticking. It got louder. By the time I made it to base. Oil Pressure was fine. I was able to trailer the car to the auto hobby shop on base. The mechanic there went around with one of them doctor things. Said hey its coming from your heads. So I removed the cover. Found a valve spring that looked pretty bad. I replaced them,also the rocker arm and push rods. Now the sound we are hearing is coming from the crank case. And well the mechanic dude at the hobby shop said it was this. It sucks I am in the Marine Corp and I really dont have much time to mess with it as I would like to.
Get a second opinion.
Auto Skills guys aren't alway the shapest..
I'm not saying he's wrong but that's a there's alot riding on the diagnosis.
Post this in a regional forum that is read by folks in your area & see if there are knowledgeble people from this site that can help you locally.
I found a place that can do the work Futeral Motorsports but the cost to pull the motor and take it apart is around the 1500 dollar range. Last I looked at my paycheck Marine Sgts dont make that much. The auto hobby shop guys are pretty good. But I really dont think they know much about LS1 Motors. The crazy thing is the car is not throwing a code or anything like that.
I've been in your shoes..I had to take out a loan to replace my engine a few years ago.
Has Futral looked at the car?
The computer won't throw codes until there's a misfire..Once the car throws a rod,then it'll misfire.You aren't there yet.
You may have simply collapsed a lifter. Spun bearings are usually intermitent and associated with an increase of rpm; they also make an indistinguishable rap-rap-rap sound. Also your oil pressure will usually be lower at idle than usual. If your car is ticking nonstop and you just replaced a bad valve spring and pushrod, then I would further investigate the lifters; just my .02
I been trying to go back to Iraq since I been down here. I am the only one of my MOS field down here. And I have 2 guys retiring so my chance's to get some real money is not going to happen. But I do have a security job on the side. Iraq would be sweet. And then I could get a Pro Charger.
Originally Posted by BYE RICE
Go do an OIF & you'll have plenty of $$$$.
Originally Posted by bjamick
If it was a spun bearing wouldn't the oil pressure drop to 0 thats atleast what ive always heard but that might just be for old school stuff.
The lifters are located under the heads, which of course means you will need to pull the heads to change them. It's not a difficult job, just somewhat time consuming. IMO the worst part is removing the old gasket material from the block and heads. Look at the bright side, if you wanted to upgrade the heads; now would be an opportune time. Now for the bad news... If it is in fact a bad lifter and you continue to drive the car; ultimately the cam will wear excessively and fill your oil with al kinds of metallic trash. This is of course a great way to spin a bearing. Dont ask me how I know this.
