arp head bolts vs. gm head bolts?
They are only better if you plan on pulling your heads more than once as they are reuseable and GM ones are not. If you intend to do this as a one-shot deal, save your $$$ and get the GM ones.
1 Post
WRONG!
When I did my first H/C swap I tried using GM bolts and while doing the torque sequence second pass one of the head bolts broke. Feel free to take your chances but I will never use the factory bolts again. Bought ARP bolts and gonna switch to studs on my new project.
Go with ARP studs...that's what I used...
Work great and they're reuseable...
Plus, to me, it's much easier to tighten the nut on the end of the stud, rather than worry about tightening that long TTY bolt...
Just don't use the stock bolts...you'll thank us. ARP bolts/studs are reuseable. The torquing procedure for the stock bolts is a pain in the ***. I found the arp bolts MUCH easier to get in and out b/c of the size of the head. It's slightly smaller so it gives u that tiney bit extra clearance to get them in and out much easier.
Originally Posted by ExceSSive
WRONG!
Originally Posted by 98_1LE
I went with ARP studs. Only complaint is that they make cleaning the deck a pain...
But, at least you don't have to clean bolt holes!!
1 Post
Then you probably were doing something wrong. How many millions of LS engines are out on the road right now using stock bolts with no problems? Just because you screwed something up, doesn't make me WRONG!
It is not rocket science to put bolts in you do turns of bolts in sequence. I am not the only one to break a bolt. And yes you are wrong, the GM bolts are not as good, just because that are "good enough" to get by does not make them as good as ARP. If that were true then there would be no market for the ARP's.
Originally Posted by erikthegoalie
i went with ARP, they are stronger, and are REUSEABLE...there's reason enough right there buddy
erik
erik
