Mid 11's Head/Cam combo
Thinking I might go ahead and dump in a heads/cam. Have a few extra bucks lying around and debating between a new motorcycle or putting it into the car. I would like to keep the price tag under $3,000. Is it possible to hit 11s without spray at this price? If so... recomendations? Would prefer to get something from Speed Inc since they are local and have done all my business through them already, but mail order isn't out of the question.... Thanks!
Current mods are as follows...
SPEC stage 4 clutch
Upgraded Hyrdaulics on trans
Hurst shifter w/Speed Inc Short shifter
Moser 12 bolt w/4.10s 33 spline
Spohn floorpan mounted torque arm
BMR lower control arms
Hooker coated long tube headers
Hooker cat back w/electric cutout
SPEC stage 4 clutch
how about:
1. get in car
2. Drive to Speed Inc.
3. Hand them $3000
4. explain what you want
really, since you want to go through them anyway that's probably your best bet. A decent heads/cam/intake setup on slicks should turn a mid 11 all day. You already have the suspension and rear end for it.
1. get in car
3. Hand them $3000
1 Post
Originally Posted by magius231
how about:
1. get in car
3. Hand them $3000
1. get in car
3. Hand them $3000
You said it! Would not hurt to go see them or call and ask whay you can get for $3000 OTR (on the road)
I've run a best of 11.73 on street tires, cam-only (232/234 XE-R) and I'll be bolting some heads on in a week or so, aiming for low 11s on E/T streets, NA. I'd think that a well matched H/C package with your drivetrain already solid should easily net mid 11s. I say go big and shoot for 10s!
Anyone running a Speed Inc cam? Now actually thinking about going with a cam only swap. Just wondering how their SI5-SI7 cams would compare to a MS4 or TREX and how badly I would be holding it back without heads.
Also, do NOT want to have to flycut....
