View Poll Results: do you think this would be a good cam for NA and future boost?
Yes
100.00%
No
0
0%
You have to be joking
0
0%
Voters: 9. You may not vote on this poll
~~Opinions... 224/232 .600/.600 115 LSA..... good cam for desent NA and boost
Old 04-25-2007, 11:52 PM
spec_j's Avatar
Exclamation ~~Opinions... 224/232 .600/.600 115 LSA..... good cam for desent NA and boost
please tell me why
Old 04-28-2007, 01:17 AM
spec_j's Avatar
anyone?
Old 04-28-2007, 07:23 AM
Irocss85's Avatar
Id say too big for stock cubic inch eng. but not by too much. also, your talking SC not tubro right? turbo the cam is VERY important to the power and boostlevels. but SC all it has to do is not bleed off the compression with too much overlap. as well as hold the valves open long enough to fill (overfill) the chamber and scavenge the exh. fully.
Old 04-28-2007, 04:46 PM
JPH
JPH's Avatar
awesome blower grind, never have used this type of profile in a n/a car, but i will work. i would rather see a 220/224 or 224/228 on a 114, this would probably be a little bit more suited for your set up, and be blower freindly also down the road.
Old 04-28-2007, 05:07 PM
spec_j's Avatar
ok sorry i didnt specify more. Im going ot be adding either twin 60mm's or a single 76mm turbo in the very near future, so i just want a desent cam untill i get the turbo on there.
Old 04-28-2007, 06:16 PM
Irocss85's Avatar
so this cam will be comeing out when you do the turbo setup? if so then its a great (mild)cam. Im SURE you'll want a custom cam speced by the turbo company for the turbo.
Old 05-06-2007, 01:40 AM
spec_j's Avatar
bump.....
Quick Reply: ~~Opinions... 224/232 .600/.600 115 LSA..... good cam for desent NA and boost
