How thick is too thick?
Old 04-26-2007, 10:56 AM
FRDnemesis's Avatar
Default How thick is too thick?
The motor I ordered from Scoggin has flat tops with -2cc valve reliefs and the piston is at Zero. To achieve the 11.75 compression I wanted, they recommended 64cc heads and .065" cometic head gaskets.
With the gaskets being this thick, are they going to be a weak point on a 150 shot of nitrous or should I be okay. Would it be safer to go with 68 or 70cc and a thinner gasket?
Thanks
Jeff
Old 04-26-2007, 10:57 AM
oange ss's Avatar
run the thinnest gasket possible and use the head cc to optimize compression
Old 04-28-2007, 02:04 PM
FRDnemesis's Avatar
Yeah, I'm rethinking it. I'm thinking more of 70cc chamber and .041" head gasket instead. I'm also thinking about putting head studs in as well.
Old 04-29-2007, 10:54 AM
NoMoreFWD's Avatar
What he said.
Old 04-29-2007, 12:40 PM
PREDATOR-Z's Avatar
If your pistons are at 0, then run a .035 cometic and size up the chamber accordingly.
If not, you first need to determine your piston/deck value and then choose the gasket accordingly.
Idealy you want .035>.040 quench.
Old 05-03-2007, 03:23 PM
FRDnemesis's Avatar
Thanks for the help guys! good information!
Old 05-04-2007, 04:15 AM
PREDATOR-Z's Avatar
BTW:
Quench = Piston to deck value - crushed (compressed) gasket thickness
