Engine assembly questions...
Old 04-28-2007, 09:42 AM
molson's Avatar
Default Engine assembly questions...
I will be putting together my LPE short block,but am not sure about a couple of things.
1-The service manual says to install the front and rear covers before the oil pan.They use a special tool (J-41480) to make sure the bottom of the cover is flush with the block.It's basically a plate that bolts to where the oil pan does and protrudes past the block.
My question is can I install the oil pan first to seat the covers?It should work the same.
2-The manual also states that the rear main seal should be installed after the cover.This also uses a special tool.I need to know if the seal can be installed before the rear cover without any issues?
Looking for any tips/hints that others have used.
Any input from tuners/builders would be very helpfull.
Thanks
Old 04-28-2007, 09:45 AM
ss1129's Avatar
Good questions. Im in the same boat as you, but I didnt know there was a tool to align the cover with the bottom of the block. I do know that when I changed my rear main seal, I used a peice of 2x4 and a hammer to get it in....like Ive done on every seal Ive changed, and never had any problems with any of them.
Old 04-28-2007, 12:18 PM
molson's Avatar
Thats good to know.....Iv'e done the front that way.
I don't want this thing to leak....It's a PIA to fix on a vette.
