Head Gaskets for Ms4
Old 04-30-2007, 10:07 AM
021less's Avatar
Default Head Gaskets for Ms4
Ok, i'm going to be putting an ms4 in my car soon. I was wondering instead of flycutting could i just get a thicker gasket and be done with it. Something like a .074 cosmetic gasket, that should give the the clearence i need. Spoke to Jon at tsp and he said if he remembered right the avg. clearance is .67 on intake and .88 on the exhaust. I think the factory gasket is .056 or something close so that should bump it up there to safe standards. I know i will be losing compression, but i will also lose compression if i cut the pistons. Let me know what ya'll think. Thanks in advance
Old 04-30-2007, 10:49 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Don't worry about changing head gaskets at all. We've sold & run hundreds & hundreds of these camshafts without any clearance issues at all. Just throw that thing in & enjoy her!
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 04-30-2007, 11:01 AM
021less's Avatar
lol, well i hope you are right, cause i really don't want to screw a 13,000 mile motor up! I have all the supporting stuff for this, including a double roller t/c. So i'm hoping all is good with it.
Old 04-30-2007, 11:19 AM
King James's Avatar
Its a lot easier to measure it instead of immediately pulling the heads.
Old 04-30-2007, 11:21 AM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
021less, what heads are you going to be running this cam with???? I have the tq 3 and stage 2.5 5.3 liter heads i was debating on going with a bigger cam but didnt want to flycut... Jason is it possible to go with the ms4 and 2.5 5.3 liter heads w/o flycutting just run a large gasket???? Or am i just retarded...
Old 04-30-2007, 12:46 PM
021less's Avatar
I'm just putting some stock ls6 heads on that i got for pretty cheap till i can afford to have them worked.
Old 04-30-2007, 12:56 PM
RGKSR's Avatar
Default Flycut them!!
I would check the PTV clearance and flycut the pistons if you are too tight.
It's not hard and I think .074 gaskets aren't the best setup. A tight quench will help with knock.
Bob K.
Old 04-30-2007, 02:02 PM
Brian @ Texas Speed & Performance's Avatar
The guy that posted P/V issues in the other thread was using a thinner head gasket & the cylinder heads have been modified from stock. Just install that thing in your stock long block & have a blast!
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
Old 04-30-2007, 02:15 PM
021less's Avatar
Thanks brian and jason, you guys have been a real help, i will be doing the swap in about 2 weeks and having vengeance racing do the tune. I will have some vids shortly after.
