what are the specs of a z06 cam
This is the production camshaft used in the 2001 Z06 Corvette. The duration @ .050" is 207 on the intake and 217 on the exhaust. It has .525"/.525" lift with stock 1.7 rocker arms and has a 116 lobe centers. GM Part numner 12560950.
"New for the 2002 Corvette, the 405hp camshaft for the LS6 engine option. Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface. Specs are 204 intake and 218 exhaust measured at 0.050. The cam has .550"/.550" lift with stock 1.7 rockers. GM Part number 12565308.
