Torquer 3 cam only
Old 05-05-2007, 04:04 PM
ls1amit's Avatar
Default Torquer 3 cam only
I have a 2001 z28 6spd I am shopping for a cam now and i have long tubes, lid and true duals. I want to run the torquer 3 or torquer 2 they both are in between to small and too big from what i am reading online. I have done searches for the the torquer 3 but there isnt much info on it. I have heard you need to run 7.425 pushrods to get optimum performance. Any one have a cam only dyno? All opinions on this cam are welcome. Thanks
Old 05-05-2007, 04:33 PM
Black_98Z's Avatar
Do you mean 7.425" pushrods?
Old 05-05-2007, 05:46 PM
blacksskid07's Avatar
+1 I'm looking at a f13, f14, and the torquer 3, for cam only. What do yall think. Im a M6
Old 05-05-2007, 10:04 PM
SweeTbone's Avatar
I ordered a Torquer V3 with 7.425" pushrods. I haven't installed them yet, but from what I've have read you will need a little bit longer pushrod than stock 7.400" pushrods. I've also read about *maybe* getting 7.450" for the intake and 7.425" for the exhaust, but I just got all 16 at the 7.425". Hopefully some V3 owner can chime in with his pushrod length.
Old 05-06-2007, 02:34 AM
bump bump
Old 05-06-2007, 08:14 AM
Fratsit's Avatar
I have been running the T3 cam only since last September. I used the PR's that TSP included with the kit (stock length). I have a slight sewing machine sound. I can hear it, although others have told me they cannot.
Here is a link to my cam only numbers after I had a local tuner play with it while I watched and learned. I am doing my own tuning now and plan to go back and re-do the VE table. I am still timming +10% in some areas.
https://ls1tech.com/forums/dynamometer-results-comparisons/610420-torquer-v3-dyno-numbers.html
R/
Frat
Old 05-06-2007, 11:55 PM
ls1amit's Avatar
Lets see some more Torquer 3's!!
Old 05-07-2007, 12:31 PM
qwikz28's Avatar
there was a PRC headed torquer 3 with a stalled auto that put down 440rwhp. its one of the texas speed workers' cars. does that help any?
Old 05-07-2007, 02:46 PM
ls1amit's Avatar
not bad. Yea im looking to see over 400 with decnent torque hopefully around 370-380 range with over 300lbs at 3000. just want to see some dyno graphs.
Old 05-07-2007, 11:31 PM
dub.ya.es.SICK's Avatar
stout stuff guys keep it coming im getting mine tuned on wed. woot! thanks guys hope it is good just wondering how muich diference i will gain power wise not driveability, off of a tune. the guy who is tuning it Hugger Orange SS here in colorado sounds like he tunes a lot and gets alot so wish me luck yall !
Old 05-08-2007, 09:36 AM
ls1amit's Avatar
https://ls1tech.com/forums/showthread.php?t=610420
R/
Frat
looking at your dyno curve the torque looks beefy 350lbs at 3k sounds great
Old 05-08-2007, 10:16 AM
Fratsit's Avatar
Hey thanks. I am pleased with it so far. Once I hit that sweet spot she pulls real good.
I see that you are being told that the T3 is too big for the street. Personally I don't agree. I DD mine and even untuned it was driveable. Very lean at WOT but driveable. She roared to life on the first crank and settled to an 850rpm idle.
I think you will be happy with the T3.
R/
Frat
Old 05-08-2007, 10:37 AM
ls1amit's Avatar
yea im looking at this cam and the ms3 with a built in advance like a 112+4 the idea just came accross my mind today after reading a post about a ms4 with a built in advance just curious about the idea. If that doesnt work out im gonna order the t3 since it has some serious lowend but the high lift makes me wonder if should change out my 90k stock lifters as well.
Old 05-08-2007, 10:38 AM
Prin's Avatar
R/
Frat
I agree. I even have heads and the car is very very streetable. There is a little surge under 1500k, but with a cam of this size you should expect a little surge.
Old 05-08-2007, 10:56 AM
Fratsit's Avatar
Give 'ole TSP a call and see what they think about the 112+4. I have a friend who has the MS3 on a 113. Drives nice and he loves it. I have not gone for a ride with him, but he says its streetable for him.
As for the lifters, because I am paranoid, I would swap them if they were mine.
R/
Frat
Old 05-08-2007, 10:57 AM
Fratsit's Avatar
Prin,
How do you like those heads? I am kicking around the Trickflows or those. How did you set them up? Milled...?
LS1amit....
I'll keep your post on target. Dont mean to hijack...
R/
Frat
Old 05-08-2007, 11:48 AM
Prin's Avatar
Prin,
LS1amit....
R/
Frat
They are milled just a tad. I think the compression is like 10.75 or so. With the heads a dn the cam, I have gained 61 wrhp. That is not all that I can do though. I have a tock pulley and stock injectors that are maxed out at the time. The plugs were tr55's and they caused a little detonation up top. Once I fix all of those things, I should be rockin and rollin...
Old 05-08-2007, 02:51 PM
transamfreak01's Avatar
not to hijackbut i was leaning towards the ms4 but now looking for something more street friendly and with not as much lope so i was thinking something along the lines of the t3.. how does this compare in driveablilty and sound???
Old 05-08-2007, 03:15 PM
ls1amit's Avatar
They said It would not clear with out fly cutting and its a straigh ground cam.
Old 05-08-2007, 05:44 PM
Fratsit's Avatar
The T3 on a 111 (as sent from TSP..actually a 111+1) will clear with stock heads. Install her dot to dot.
The idle is very respectable. Has a mean lope and will turn plenty of heads. I run Jethot longtubes, a Mufflex ORY, and a Borla catback. Instead of using the Borla block off plates I installed a QTP cutout.
Driveability is fine and only gets better with a good tune. I had a little cam surge in the lower gear/rpm range. I recommend against going WOT until it is tuned. My LTFT's had been maxed at +25% prior to the tune and she was running lean both in normal driving and WOT.
This cam will like a bit more gear. I figure 3.73 or 4.10's.
Again... you wont be dissappointed with the Torquer 3.
R/
Frat
