HOW TO "flycut pistons"
Old 02-02-2013, 11:56 AM
  #61
Don Nguyen's Avatar
Old thread, but what is the best way to measure the fly cuts on a piston that's already been done? I bought a block with some fly cut pistons in it already and I just want to double check what their depths are.
-Don
Old 02-06-2013, 09:26 PM
  #62
Irocss85's Avatar
well, a graduated cylinder. same as used to check the cc of a piston or chamber. anything else is a guess. why are you wanting to do this? just to see what your static comp. ratio is?
Old 02-06-2013, 09:38 PM
  #63
Don Nguyen's Avatar
Bought a block with pistons that were already fly cut by another shop. Owner doesn't know the depth and I just want to verify what it is so I can determine if I need to do them deeper or not.
-Don
Old 02-06-2013, 10:10 PM
  #64
Irocss85's Avatar
post #1, step#9. but youll still need to mock it up and measure ptv to be sure.
Old 12-17-2013, 09:18 PM
  #65
bmeyer40's Avatar
Thank you for the write up.
Old 01-11-2014, 03:02 PM
  #66
Poppa G's Avatar
Default piston fly cutter
Hey Irocss85, I know it's an old thread but do you still have the piston fly cutters? If so would you be willing to loan or sell them? Thanks John
Old 01-11-2014, 05:17 PM
  #67
Irocss85's Avatar
pm sent poppa
Old 02-20-2014, 07:42 PM
  #68
DoggyB22's Avatar
Thanks for the info!
Quick Reply: HOW TO "flycut pistons"
