procharger track results!!!!!!!!!!
Old 05-07-2007, 10:26 PM
kngkahious's Avatar
Default procharger track results!!!!!!!!!!
what kind of track times can i get out of this setup.it is a vert and a m6.all openion's will be appreciated.i'm thinking it should be in the high 10's.
Procharger P1-SC Twin intercooled 7psi polished air box
45lb injectors
100psi fuel pump
Deablosport programmer
Dual friction centerforce clutch
Dynateck 1 ¾ to 1 7/8 long tube headers ceramic coated
Custom Y pipe
S.S. magnaflow, flow through muffler
Snow performance Water/Methanol Injection sys.
KYB adjustable shocks all 4 corners
Eldibac lowering springs all 4
Rk sport traction bar.
All rear linkage replaced with aftermarket
Cromoly Roll cage(added 100lbs)
Old 05-07-2007, 10:34 PM
noxiouSS's Avatar
move it to the forced induction section
Old 05-07-2007, 11:28 PM
kngkahious's Avatar
i've already tried the f/i section got no response.
Old 05-08-2007, 12:46 AM
PREDATOR-Z's Avatar
12s maybe high 11s with some sticky tires.
If no tires you'll be dissapointed.
