TR 224/224 112LSA Dyno #'s
Finally got the car on the dyno and got it tuned yesterday. With the TR 224 cam and the other mods in my sig, it put down 375/375 SAE at the wheels. The more impressive part was the torque curve. FLAT!!! It does not go under 300 lb/ft ANYWHERE on the graph. That is from 2000 RPM all the way to red line. It is over 350 lb/ft from 3000-6000. I was hoping for a little better peak numbers, but seeing that fat torque curve on there made up for it in my mind.
For anyone thinking about this cam, it is VERY street friendly. My car is a 6-speed. Now that it is tuned, it drives pretty much like stock, just a lot meaner.
1 Post
Nice #s there...I have the same cam and did not put down as good a #s as you in my A4. Well I was never cam only but with Patriot stage IIs I only put down a small amount better than you and with a Fast 90 added anther 11.
impressive i had this cam before and i told all my friend to go for it if they want crispy
mean engine with street manners and ,i had simillar dyno# with cam only 370/365 .and with heads its put 400 easy with verey bad tuning.
I LOVE THIS CAM TR224 114
