Trouble deciding what heads to compliment the Vindacator cam?
I know the TFS are the best but can't afford those heads since I just bought a Moser, so I've been looking for some budget and used heads. I've had 2 in mind. The MTI 2r heads and TEA 5.3L stg 1.5 heads. Both are used and was curious if those would be good set. Anyone elso have a different option?
LS1 Tech Administrator
All are excellent, but the TEA and PRC 5.3L heads have been updated several times the past 2 years and are making some outstanding numbers.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
The ones above are excellent, but keep in mind, added static compression will best compliment this camshaft. Getting 11.0:1 or higher is a real plus. A 61cc head with average flow will often make more power than a 66cc head with excellent airflow.
Also, remember that most any high compression head with larger valves is going to require flycutting of your stock pistons to ensure adequate piston to valve clearance with the Vindicator cam.
__________________
So a 5.3L head would work great with this cam?
Originally Posted by 00 Freak
I know this is a fairly new cam on the market but anyone have a good idea what heads would be good with this cam. Thanks
The Vindicator (240/244 .608/.598 112+4) Loves RPM, You are going to want serious Flow up top.
If it's between those two heads i would say the PRC's, like patric said they have been updated several times.
I'm not sure if MTI ever revised the port design to meet the new style cams. Being you don't hear from them much anymore, Back in the day of "small cams" (when a MS3 was giant) the heads were amazing.
If you can splurge a bit more the TEA AFR 205's or the Trickflow 215' would be best.
Originally Posted by Alex @ CMS
Is this going into a stock CI motor or a stroker?
Anyone else would like to give me some advice on which heads to go with.
