Max stock crank HP
Old 05-10-2007, 08:34 AM
GTBAF333's Avatar
Default Max stock crank HP
What are your HP numbers on a stock crank ??? Trying to figure out if I can safely get away with shot-peening the crank, H-beam rods, and forged pistons. I've done this on typical SB chevys and I'm sure it would work for an LS1, but I'm new to the LS1 world. Going to be doing heads/cam, and nitrous. Let me know.
GREG
Old 05-10-2007, 10:34 AM
04A4GTO's Avatar
The stock cranks have proven to last at 900 HP
Old 05-10-2007, 11:27 AM
twolfe's Avatar
I've seen people running about 850HP with a stock crank. It can be done.
But from the reading that I've done, you don't want to cross the 600HP mark.
Over 600 and you are driving time bomb.
Old 05-10-2007, 11:46 AM
y2khawk's Avatar
try 1K+ rwhp, we figured mine was approaching 1400 at the crank.
Old 05-10-2007, 12:31 PM
GTBAF333's Avatar
So I should be alright with 500 rwhp and spraying 150-200 ?
GREG
Old 05-10-2007, 12:45 PM
PREDATOR-Z's Avatar
Duh?
Y2Hawk just told yois is boosted to 1400Hp at crank
You can always cryo or nitrate it if you want more out of it.
Old 05-10-2007, 01:09 PM
gun5l1ng3r's Avatar
What is the was all about?
Did the crank finally break?
Old 05-10-2007, 03:06 PM
y2khawk's Avatar
nope, torn the car down. The block, pistons, and crank have been in my truck for the last 35k miles. Daily driver at 12 to 13 psi on 93 pump, figure that's in the 700 crank range Had to rebalance for steel versus aluminum rods, that's about it.
I've never had a stock crank fail, but then again I didn't want to push it much farther than I was.
Old 05-10-2007, 03:07 PM
david vericker's Avatar
GREG
The LS1 crank is buy far the strongest part in the stock bottom end. With forged rods and pistons your good for 800 + rwhp.
Old 05-10-2007, 09:17 PM
GTBAF333's Avatar
Sounds like I will be good then, thanx
