Has anyone put new roller rockers on ls1?
Old 05-12-2007, 02:29 PM
maddymac07's Avatar
Default Has anyone put new roller rockers on ls1?
for 400 bucks is it worth it any dyno numbers before and after? what rwhp can you expect by changing these?
Old 05-12-2007, 02:40 PM
1BADAIR's Avatar
I don't think they are worth it. Many very high HP cars are running stock rockers. Alot of the cheap aftermarket rockers are too heavy over the valve tip and cause valve float
Old 05-12-2007, 04:01 PM
maddymac07's Avatar
that almost makes my decision i should save for new heads. anyone else any imput
Old 05-12-2007, 04:14 PM
Tainted's Avatar
go for some rebuilt stockers
Old 05-12-2007, 10:28 PM
1BADAIR's Avatar
yeah the harlan sharp rebuilt ones are very good. You won't pick up power they just make them so they can't spill the rollers out
Old 05-13-2007, 08:32 AM
Moderator
davered00ss's Avatar
The scorpion ones are supose to be good. but I haven't seen any results yet.
Old 05-13-2007, 09:34 AM
vettenuts's Avatar
Cranes will get you something but not sure what you are trying to achieve. Roller rockers based on my experience have a better wipe pattern than stock as well.
Old 05-13-2007, 05:33 PM
maddymac07's Avatar
i'm lookin for horsepower anywhere i can find it without chaging heads for 3 grand anyone know any cheap heads that are good
Old 05-13-2007, 08:55 PM
z28misfit's Avatar
I don't know really much at all about rockers myself, and I too was wondering if the Harland Sharp rockers are even worth getting when I purchase better pushrods. I've heard the aftermarket roller tip rockers have a problem with being heavy. When I got my cam from LG, that's what they told me. But like others , I too was hoping to find a good trust worthy set that will net me at least a couple hp because heads are out of the question for now.
Old 05-13-2007, 10:24 PM
1BADAIR's Avatar
harland sharp modifies the rollers in the stock rockers so they don't fail. I tried the harland sharp pedistal mount rockers and my car floated the valves at 5000rpm cause they are so heavy
Old 05-13-2007, 10:40 PM
Super Hulk Smash
JakeFusion's Avatar
If you are running TFS heads, you'll need to run the Harland Sharp or Jesel rockers (or Yella Terra lightweights).
Otherwise, the Harland Sharp rebuilds or Crane Golds will work well for you.
Old 05-14-2007, 07:20 AM
RZRSEDGE's Avatar
I have the Harland rockers. Seem to work well; but did'nt notice a SOTP increase. Also, I have had no valve float and shift mine at 6400 and have taken to 6800 with no problems.
Old 05-17-2007, 02:33 PM
z28misfit's Avatar
I just want to make sure of absolutley no vavle floating because I cross the line at 7k and with 4.56gears, the car tachs up real fast. I don't think the x4 cam is too forgiving with valve clearance. Maybe I'll just stick with the stockers for now and wait and see if how the new Scorpion rockers are doing.
Old 05-17-2007, 09:27 PM
mrr23's Avatar
then the vinci/crane 1.8 accelerated lift rockers will do the trick for you. here's a dyno from the wife's car. stock cam, stock tune.
